"Distant Lights" refuse to render to Canvas
well as the topic says I can figure out how to make the distant light render to a canvas,..everythjing I've tried just renders out black
  • Are they working in a regular render? What is the Environment Mode set to in Render Settings (after adding an Environment Settings node or doing an Iray or Filament render or draw)?
  • TannimTannim Posts: 46
    appears like it should,.. and scene only
  • Which canvasses are you using?
    I've tried it as a  Lightgroup,  w/ the distant light selected in the nodegroup, I also did a LPE, with Advanced node on the Distant light named Distant and the Expression <L'Distant'>.*E
    So Apparently,  Distant Light,. is considered Enviroment,.. not a light like the other lights, but I guess I shouldnt be surprised, the emission never does well for me.. use light group for them as well as normal lights so why would Distant not be head scratchingly weird,
