• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Cinema 4D Discussion
Character facial features are different with FBX import
gm.rogier.thegm.rogier.the Posts: 0
February 2022 in Cinema 4D Discussion
Hi guys,
I made a character in DAZ 3D and I have exported it to a FBX, however when I import it in Cinema 4D, the facial features and morphs are not there anymore, it looks almost like a plain face.
Pease see the screenshot attached,  I madea samurai type of character in DAZ 3D and when imported in Cinema 4D it almost looks like a regular genesis character, all the asian face features have dissapeared
I am doing something wrong during exporting? I also attached my export settings
I would appreciate any help, thanks!
  • GordigGordig Posts: 10,658
    February 2022 edited February 2022
    FBX exports at base resolution, so it's possible that the character you're exporting relies heavily on subD to look the way it does. Set the character to base resolution in DS and see how similar it looks to your imported character in C4D.
    Post edited by Gordig on February 2022
    Here, I did it for you:
    As you can see, it loses a lot of detail. Maybe you could export Daiji at full resolution as an OBJ and drop an LOD modifier on the FBX you imported?
    1200 x 1600 - 2M
  • gm.rogier.thegm.rogier.the Posts: 0
    February 2022
    Hi @gordig, thanks so much for your help and apolagies on my late reply. Could you please explain me how to set character to base resolution in DS? what do you exactly mean with DS, quite new to this all!
    Also with  LOD modifier do you mean LOD object in Cinema 4D?
    Thanks again!
    February 2022
    DS is Daz Studio, in case that was unclear. To change mesh resolution, you would go into the parameters pane, under General -> Mesh Resolution. There, you can toggle between base and high resolution in the drop-down menu, and change the viewport and render subD. FBX exports at base resolution, and I'm not sure if there's any way around that. If you've already animated in DS and just want to export to C4D for rendering, you could try exporting as Alembic, particularly using the free Sagan exporter by @themysteryisthepoint
    Yes, that's what I meant. I've only dabbled with that, and after further consideration, I don't think just dropping a higher-resolution OBJ in the LOD object would actually work because you'd have to transfer all the weights over to it, but I'd be happy to be wrong about that.
    March 2022
    @gordig
    Changing it to base via parameter tab worked perfect, thank you very much!
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
