Why does my viewport look all washed out?
Hi all, I am experiencing something new here I have never seen before. Whenever I load a object, human, clothes, anything, it loads all washed out looking. No contrast. And if I select a background image or color, it does not show in the viewport, nor will it render in viewport setting, you just get the gray tiny squares of no background.. Only will it show in a Iray render, but not in the viewport. This weirds me out because I can't pose anything with no background. This is the new Daz 4.16 this is happening with. It looks real bad. Any clue as to why?
  • GordigGordig Posts: 10,840
    Can you post a screenshot? Also, what viewport drawstyle are you using? It sounds like you might be in Filament mode, but it's hard to know for sure without seeing what you're seeing.
  • music2u4umusic2u4u Posts: 2,822
    That would be it! I changed it to the right setting and the backgrounds are there now. Thanks.
