Several Uninstallers Left with DAZ4.7 upgrade
inquireinquire Posts: 2,464
Just upgraded from D|S 4.5 to D|S 4.7 a few days ago. As uninstallers I have Decimator, GoZ, and keyMate. When I check the installed plugins, however, they are not there. Perhaps they were removed with the removal of v. 4.5 and the upgrade.
Question: should I reinstall these, or are they somehow included in the new version, 4.7, of D|S?
  • Richard HaseltineRichard Haseltine Posts: 111,734
    Installing DS 4.7 should not removed the plug-ins. However, if you had previously used the stand-alone installer and this time sued DIM the application may have ended up in a different place, and therefore may not be finding the plug-ins. Uninstalling and reinstalling the plug-ins, using the same method as for installing the application, should fix the issue in that case.
  • inquireinquire Posts: 2,464
    Thank you. That seemed to have done it. Plugins now show up as installed.
