Adding to Cart…
Thank you! I don't have Daz Studio from that far back, but the one from fast3d looks pretty good. I appreciate it!
Did anyone know where I can get the Lara Croft necklace? (must not be a freebie)
Not free but low priced: https://www.cgtrader.com/3d-print-models/art/scans-replicas/2018-lara-croft-tomb-raider-necklace-pendant-medallion
Mhh is that with this two times wrapped leather necklace, or just the medaillon? because that's the look I searching for. Saw it in many renders but was not able to find a source.
stumbled upon this per chance, thought hey why not a dragonfly.. wayback machine link gives me an error msg "wb_app_pygwb’s server IP address could not be found."
That is a wayback server error so the only thing you can do is try later. I checked some of the other Wayback Machine links and got the same type of error. So Wayback is partially down.
Looks like the Wayback Machine can now fetch zips so you should be able to get that dragonfly now,manekiNeko.
I seem to remeber seeing a figure years ago, but I can't remember if it was a freebie or not. It was a fly, but human sized and stood and posed like a human, I think there was a wasp also. Unless my memory is playing tricks on me.
They were by Noggin and are still available but not free:
https://www.daz3d.com/insect-i-vore-the-fly
https://www.daz3d.com/insect-i-vore-the-wasp
There is also a roach: : https://www.daz3d.com/insect-i-vore-the-roach
To take a look at M. Heyev's freebies before downloading them (rather than hotlinking the ZIPs themselves like the dragonfly above), the page is here:
https://web.archive.org/web/20070518081409/http://www.mikheyev.rgkp.com/page.asp?mart=40
Thanks for the link.
I just found a TV station video camera on Blendswap. That means it is in Blender format. To use it in Daz Studio, you will need to load the model into Blender (which you can get for free), and export the camera as an .obj, then import that .obj into Daz Studio and apply your own shaders to it. https://www.blendswap.com/blend/2765
Anyone know where I can get a duct tape freebie that wraps around an object?
Are there any freebes of a Dusk auto-fit clone for Genesis 3 Male, Genesis 8 Male, and Genesis 8.1 Male figures?
I don't know of any duct tape--like prop that can conform to the contours of an object. But if you don't need the realism of a duct tape wraped around something in a skewed way, you can use mcjWrapABand script. It will put a band around any object in Daz. And you can adjust the width to that of duct tape. You can texture it to look like duct tape 'cause it is UV mapped. But it will look as if someone had applied the duct tape with no skewed overlaps, perfectly lined up with the lower layers, 'cause it is just a band.
https://sites.google.com/site/mcasualsdazscripts9/mcjwrapaband
I found a ticket dispenser for Blender. If you know how to convert from Blender to Daz, it could likely do the job.
https://www.blendswap.com/blend/4369
I'm not sure if this was already asked, but does anyone have models of a human and dog skeleton? I'm trying to model my furry-but-make-it-body-horror monster and I'm not confident enough in my skills to try and do the whole thing myself without some sort of base XD
Can someone create ears like the Shai character from Black Desert Online? https://www.deviantart.com/edthebuilder007/art/Litlbit81-858087333
Has anyone seen any freebies that look like animal dens? Like a mound in the ground with a hole in it? I need one badly for a project.
Rather an odd request, I guess, but does anyone have a lead on a reasonably accurate greyscale height-map (potentially a displacement-map) of the planet Mars?
Hi there, I'm looking for a hairband prop (green thing in pic) if anyone could take a stab at making it or send me in the right direction.
Thanks!
Any of these work for you?
From a google search: https://www.google.com/search?q=mars+heightmap+nasa&tbm=isch&chips=q:mars+heightmap+nasa,online_chips:grayscale:S34TLDaWR18=,online_chips:elevation:i1PVrujyGTk=&hl=en-US&sa=X&ved=2ahUKEwiboIiw-4z2AhUHS1MKHTqlDEAQ4lYoBXoECAEQJw&biw=1407&bih=668
Yes! Thank you!
And here I was all set to try blodging one out from the +5Gb TIF layers from that over-technical website I found...
Does anyone know where I can find some textures for the old V4 Morphing Tunic set? I'm planning a render and that set works perfectly for what I want.
Thanks!
Sandy
Can't find a V4 one, but the V3 one has a number of links to freebie textures here: https://poserdazfreebies.miraheze.org/wiki/V3_Tunic
Regards
Richard
I have updated the V3 Tunic wiki page to reflect that V4 Tunic can use these textures as well and have added a few more sources for textures.
I made a mound with a hole in the SIDE of it. I have not released it yet, but I can send it to you as it stands now. Although it's not finsished yet, the unfinished stuff is just additional items to make it serve as a night club or a bunker. Since you don't need that stuff, the basic mound with hole in the side might work just fine for you. It would likely be untextured, so you would have to apply some kind of ground texture shader to it. Here are all my pictures of it so far: https://www.deviantart.com/luqu/gallery/77296361
Those pictures don't show how big the ground is that I made to surround the mound. There's a lot of that ground, actually, in case you need it.
I ended up using something more fantasy-like (like a Hobbit house), but that looks like something that would work really well! I'll wait until you have it finished, but that will certainly be very useful. Thanks for letting me know about it, I've bookmarked your page so that I can download it when you're done ^_^
Right on.
