3D Universe Toon Cow
digitelldigitell Posts: 591
I just purchased the Toon Cow and there is an issue when I dial in the >Body>Morph>Body Shape>Calf,
The hip/buttock area distort greatly. (See attached image).
Every other body part scales to a calf but the hip and buttock area remains distorted.
I am using Poser Pro 2014.
Is this a known issue or a fix for this? Any help would be appreciated!
Thank you!
  • SpitSpit Posts: 2,342
    All I can say is this doesn't happen to me in Studio. I don't have Poser to test.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,400
    well if it is like the toon goat in carrara losing its horns and ears, turning off inverse kinetics to pose was the answer
    admittedly I have the cow too but not tried either it or goat in Poser yet but may be similar issue as it is a DAZ studio rigged figure
    once "fixed" I could save it in carrara and reuse fine so cow prob too resaved after as a new cr2
  • digitelldigitell Posts: 591
    Thank you for your replies. I thought of Inverse Kinetics but that area is greyed out and not available with this figure oddly enough.. I did send a note to 3D Universe over on their website but I think it is a weekend time for them and may not hear anything until next week. Thanks again for trying to help!
    Cheers! :)
    edited December 2014
    Cheers! :)
    I don't have this item but was wondering if it is a duf weightmapped file how are you getting it into poser? Are you exporting as a cr2 or using DSON? Or has 3Duniverse provided a poser cr2 in the product? That looks like it could be a weightmapping issue...I have seen similar problems when using poser weight mapped in DS.
    Post edited by Pendraia on
    Pendraia said:
    Cheers! :)
    This was released back in 2012 and 3DU has included CR2s for the various parts according to the readme, to enable it to be used with the DSON importer.
    chohole said:
    Pendraia said:
    Cheers! :)
    Thanks Cho...if it is an older product and included CR2's it may be an issue with Poser 2014. Has the op got all the service packs installed?
    Hello,
    Thanks so much for the input on this issue. Yes I have the service packs installed. I use the DSON importer that is provided with the product. Also I found that the same thing happens when I use the Stylized Cow morph. I hope to hear something from 3D Universe next week. Maybe they will have a solution for me. Thanks again! :)
    Post edited by digitell on
    digitell said:
    Hello,
    Sorry I couldn't help more...I'm sure 3DU will be able to help though. I don't use DSON though I did recently pick up a copy of Poser 2014. Just wondering does DSON require updating for 2014? Or is there an update? If this is an older product it may be something in the transfer process...
    Hi Pendraia, Thanks so much for trying to help. :) It is an oddity I guess 3DU can maybe figure out. I guess no one else has had this issue?? Or have not mentioned it. I can still use the cow, which is adorable! I love 3D Universes products! Not sure about an DSON update?? I rarely use it, I dont use Genesis items much at all, but it seems if there was an update needed we would see it listed somewhere.
    Thanks again and have a lovely weekend!
    No problem...I love 3DU's stuff he is just very clever I love his stuff for Dawn and also Genesis. I hope you have a good weekend!
    You have a great weekend also Pendraia! :)
