Iray Ghost Light Fix (dse) for Daz Studio 4.20 o later
jag11jag11 Posts: 885
edited March 2022 in Freebies
Small script to fix the ghost lights. This script enables the advanced Iray properties including the "Iray Visible to Primary Rays" property.
Brief instructions:
  1. Download ZIP from the link below
  2. Save the content of the ZIP file in your Content Library/Scripts
  3. Execute "IrayGhostLightFix.dse"
  4. Select the emissive node you want to fix
  5. Click "Repair" icon button.
After executing the script check your Parameters tab, you'll find two new properties "Enable Iray Matte" and "Iray Visible to Primary Rays" under path "Display/Rendering/Iray".
The property "Iray Visible to Primary Rays" controls light geometry visibility On = light geometry visible, Off = light geometry not visible.
HTH.
https://www.daz3d.com/forums/uploads/FileUpload/81/d090a788c1454f67863c1b4273188c.zip updated 20220313 19:15
Post edited by jag11 on
«134
  • Thank You :-)
  • lukon100lukon100 Posts: 849
    Cool. Thanks so much for makin' this fix.
  • memcneil70memcneil70 Posts: 5,667
    Thank you @jag11. And for also telling this 'idiot' how to install and use!
    Mary
  • khorneV2khorneV2 Posts: 151
    awesome ! thanks a lot !yes
  • GreymomGreymom Posts: 1,146
    Many thanks!
  • edited February 2022
    When I select the emissive surface and run the script I am told it failed to load.I also tried by selecting the ghostlight in the scene tree.
    Post edited by Second Technician Rimmer on
    Which version of Daz Studio?
  • It's 4.16.03.
  • You need to be using the latest Public Build to benfit from the script, and as it is .dse it will check that the version running it is no older than the version it was saved from.
  • jag11jag11 Posts: 885
    That is correct, script was created with Public Build version 4.16.1.40.
    I'll correct the post title to avoid confusion.
    Save this script "IrayGhostLightFix.dse" in your Content Library/Scripts.
    In order to run you need first to select the "Emissive" nodes you want to apply this fix.
    HTH.
    And where is the script?
  • How do we decrypt the file?
    HTH.
     It is on the original post, at the very top.
    It is a user facing file, it is not meant to be decrypted.
  • I see. I asked because it didn't work for me, guess I'm doing something wrong.
    Check your DS version, also check log file for any messages Help|Troubleshooting|View Log File ...
  • I live in hope, but will there be an actual fix so ghost lights will work? I used the script, it says it worked in the log file, but everything is still dark in the scene. I`m a bit frustrated because I use ghost lights a lot, and this is stopping me from actually doing anything at the moment. Maybe I`m just thick and did`nt use the script properly the first time, I have no idea.
    I just updated my DS this morning to 4.20, ghost lights are not working, even after using the script. Log file says it worked, but my scene does`nt show them. Maybe I`m just stupid.
    Same issue. Script does nothing for 4.20.
    Don't say that. I'll check it and will post a fix in case of a problem.
    I've just installed 4.20 final release.
  • Aldor64Aldor64 Posts: 37
    Thank you very much for your effort! I am (as many) others looking forward to the fix!
    Post edited by Aldor64 on
    +1yeslaugh
    Thank you!  I tried the script this morning and no luck.
    I've updated the script. There's a download link at the original post.
    Cheers.
    Cheers.
    thanks a lot  again !!!yes
  • I think i found a easy work around to make Ghost Light mod work. All i did was apply the light shader to the surfaces tab first rather then last. Then i applied the utilities last rather then first and the prop emited light with the source not visible as it did prior to 4.20.
    Cheers.
    I got a bit further along, I managed to execute the script, got the little window pop up and it had found the ghost light, I clicked on the apply button, but it did`nt do anything, sorry  frown
  • DresdenskinDresdenskin Posts: 56
    It seems that the script does not affect anything related to the Surfaces tab. It adds two parameters to the "Display" section of the Parameters tab for the objects it is applied to.
    These parameters are "Enable Iray Matte" and "Iray Visible to Primary Rays".
    To enable an object to become a true Ghost Light, the "Enable Iray Matte" parameter needs to be ON, and the "Iray Visible to Primary Rays" needs to be OFF. This makes the object invisible in the render, but still emits its light. If you turn off the "Enable Iray Matte" option, the object remains invisible, but will still be visible in reflections. Turning ON the "Iray Visisble to Primary Rays" option makes the object visible in the scene.
    EDIT: One additional note: The script detects objects in the scene that have light-emitting surfaces. i.e. any objects that have a surface or surfaces where the Emission Color parameter is set to any color with a Red, Blue or Green value of 15 or higher (or =>0.0020 on the color bar).
    EDIT2: I've noticed that, despite the Iray Matte being ON and the Primary Rays OFF, the emissive object is still visible in reflections as a black matt object if there is also an environmental light (or HDR) in effect which, to me, means it is not a true ghost light.
    1377 x 925 - 566K
    Post edited by Dresdenskin on
    PaulaDegg said:
    Cheers.
    Make sure Iray is not rendering in the Viewport before executing script or Iray won't notice the fix.
    HTH
    322 x 316 - 17K
    What I do for cases like that is change Scale so small that no light geometry is perceived in renders.
