Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
How do I find "install directory"- it will start with the word data also?
then look into data > DAZ3D > Genesis > Base > Morphs
Remember when you used the "show installed files" to see where the product files got installed?
The install directory for that product is the path at the top of the list, in this case C:\Daz 3D\Applications\Data\Daz 3D\My Daz 3D Library
This should be it I'm pretty sure.
So the files are actually there, in a directory that DS knows. I really don't see why it wouldn't find them then...
Did you maybe also install them with Connect (directly inside studio)?
I install everything through central, should I uninstall and reinstall through DIM , will that make a difference?
I'm sorry, but what is the current topic? It seems to have gone from the Body Morph resource Kit 4 for Genesis to Kids 4.
it started here near the beginning, sorry I think that was before you told me to stick to one topic per post, should I start a new one at this point?
Current topic is the Body morphs ressource kit 4, which apparently doesn't appear in the list of Genesis morphs in Parameters tab. They seem to be correctly installed, in a content directory DS knows, so I'm a bit out of ideas...
I got mixed up at some point and thought it was a V4 morph pack, not a Genesis one, so there are a few off topic posts in the middle...
