will all genesis male outfits fit fine on genesis female also?
One I have does fine but before I boguth another outfit I wanted to see if  I can buy it knowing it wil lwork or if it is just a chance it will work or may noit. thanks
«1
  • LeanaLeana Posts: 13,502
    Yes, outfits marketed for Genesis 1 Male will also work with the female morph. They were optimized for the male morph, though, and may not provide a custom fit for the female morph.
    Is there a specific outfit you're wondering about?
  • VicSVicS Posts: 1,273
    this is the one Leana thanks,
    https://www.daz3d.com/marauders
    Quick test render of the outfit loaded on Genesis base female morph, seems to work fine to me.
    1044 x 793 - 404K
    Thanks Leana,
     I got the https://www.daz3d.com/genesis-head-morph-resource-kit-4
    it says there are 11 face morphs but in parameters i see no sliders for new faces and there is just one icon in library, no faces there either
    Also I already have https://www.daz3d.com/genesis-evolution-head-morphs
    so I do even know if new sliders that come wit hthe resource kit have added, there are no sliders wit hnew colors
  • MelanieLMelanieL Posts: 7,867
    edited January 2022
    vic3d said:
    Thanks Leana,
    Try looking here:
    By the way the sliders are all light grey, so no new colours to identify them.
    889 x 739 - 100K
    Post edited by MelanieL on
    edited January 2022
    Morphs sliders from different packs don't always have different colors, especially not for older figures.
    You can use the morphs groups in the shaping or parameters tab to find groups of morphs. For the Morph Kit 4 there's a subgroup under "Head":
    566 x 314 - 65K
    Post edited by Leana on
    I guess it di d not get installed, it was through daz central,
    also the one icon it has in library is black with no image
    940 x 871 - 211K
    I uninsatlled and reisntalled through IM. still nothing. Does reinstalling through IM even do anything with any products?
    Where did you install it exactly?
  • HLEET_3DHLEET_3D Posts: 172
    Just don't expect good thing for the other way around : female cloth on male genesis !
    I tried it :D
    Leana:Where did you install it exactly?
    I do not know, I jsut clicked install on IM, I can check further please tell me how.
    thanks
    According to the readme, the morphs technical files are in a folder under the following path: data\DAZ3D\Genesis\Base\Morphs\HSTW\MorphKit4
    Where is that folder on your drive?
    Mine doesnt  have the base folder so I can't search past Genesis
    And many if these products, not only M4 and genesis character related ones, are still installing with the warning mark at the icon in library.
    Also is this white
    box in each one's top right corner supposed to be there?
    They all have it in this image except for day at the beach which has a green box in the bottom right corner
    744 x 1176 - 225K
    I’m asking where it is on your hard drive, not in DS. The data folder will not appear in DS, and that’s normal.
    When i pasted your link/thread of the location and hit enter nothing happened so I found my way there where I showed you, was your thread complete? I thought it was missing the first part it can't start with"data"can it?
  • You need to use a file browser to look, not Daz Studio.
    I was looking in file browser, I paste location, hit enter and the file browser doesn't go anywhere, stays where it was.
    2024 x 1100 - 957K
    edited January 2022
    No, the path is not complete, the first part will depend on where you installed the product and I don't know where that is. That's actually what I would like to know ;)
    You said you installed it with DIM. When you go to the "Installed" tab and right-click on the line corresponding to the Morph kit 4, you should have an option to "show installed files". What does it show you?
    Here it is , thanks
    1238 x 1430 - 702K
    OK, so the first link is where you installed it.
    Is that folder listed as a "Daz Studio formats" content directory in DS preferences?
    Is this where you mean? Or what tab is it?
    2212 x 1568 - 118K
    edited January 2022
    Go to Content tab, then open the "content directory manager". There should be a content set called something like "current content set" or "current directories", with a list of "Daz formats" content directories.
    Visual aid
    564 x 532 - 60K
    384 x 240 - 19K
    Thank you, this should be it.
    1278 x 1296 - 196K
    edited January 2022
    Sorry, I forgot we were taking about V4, so it was "poser content" we need to check.
    So it is in a Poser content directory. Is that the same one where V4 is installed? For M4 and V4 the figure and its morphs pack have to be installed in the same content directory, or it won't work. You can check where V4 is installed with "show installed files" too.
    this is where I am still look I hope, I can't find anyhting like v4 base to check, is there anything here I should check? there are only a few item underneath that are also just products
    2370 x 1850 - 415K
    Try looking for "Victoria" not V4
    Here it is.
    1712 x 1638 - 392K
    My bad, I just realized I got confused between all your threads sad.Morphs Kit 4 is for Genesis, not V4...
    If you go to the install directory on your drive, then look into data > DAZ3D > Genesis > Base > Morphs, is the HSTW folder actually there, with the MorphKit4 folder inside?
