dForce strange attractors
marblemarble Posts: 7,500
edited January 2022 in Daz Studio Discussion
Here's an example of a quirk with dForce that is quite bothersome.
This morning I bought this dress because it has buttons which can be opened. Well, actually that's not quite correct: I was a little disappointed to find that there are no parameter sliders to open the dress; instead there are four different load options with the dress in four different states of "openness". However, I digress.
The problem I have which is ongoing with dForce is that the mesh gets pulled towards other mesh objects quite unpredictably. Quite often these are fingers or props which are visible to the simulation even though they are not in contact with the cloth mesh. Yes, we can turn off visibility but it looks to me like a bug.
This dress shows the problem in a different way. After loading the version with a partial skirt open and ran the simulation, I find that one flap of the skirt is attracted to the other so the drape does not work as intended. I just wonder if anyone has advice abut how to stop dForce from being dragged towards unattached mesh?
Post edited by marble on
  • As for undoing, there are probably dForce add-ons parented to the dress, one per button, and you can also undo it by deleting those.
  • marblemarble Posts: 7,500
    Yes indeed, every button has simulation properties that I don't understand. Maybe you (or someone) could elaborate?
  • PetraPetra Posts: 1,157
    May I ask what dress this is?
    I linked it in the text but it is this one ...
    dForce Asymmetric Button Dress for Genesis 8 Females | Daz 3D
    If I am right, go to the Scene pane, expand the Genesis 8 figure, then the dress, and you should see new nodes (not bones) for each button - not Rigid Follow nodes with a button parented to them, but probably figures probably with add-on or closure or the like in the name. Select the ones you don't want and turn Off Visible in Simulation in the Parameters pane. The add-ons are invisible ties that attach two (or more) vertices to each other.
  • docbotherdocbother Posts: 108
    It is almost like the buttons or the dress have a really high friction value so that if they touch at some point in the simulation they get stuck like superglue. That's just a WAG.
    edited January 2022
    I take it you mean the Button Links in the scene tab? Even so, I'm not sure how that will help. The thing is that I have other dresses which open and they have a parameter slider which pulls the cloth aside (a morph, I assume). This dress comes with four different load states as you can see in the screen shot. So If I have the character wearing the dress in a series of scenes (which is how I work with DAZ Studio) then I have to delete and load another dress option if I want to show an unbuttoned drape. I do make my own morphs for clothing quite often but my skills (and software options) are limited.
    Nevertheless, this is something of a distraction from the original question about why dForce has this odd habit of sticking to mesh that it is not initially touching. To be clear, I wasn't saying that the dress is being pulled towards the buttons. In the image attached to my OP the mesh to which the dress is stuck is actually the left thigh of G8F. A real-life drape would have that flap of the dress falling but that corner of material just sticks like glue to the thigh.
    355 x 437 - 30K
    493 x 871 - 62K
    407 x 673 - 48K
  • Yes, the Button Links will be the ties. The different presets will have different numbers of those included.
    Thanks - that does the trick if I want to remove the influence of the buttons and then drape which turns out to have better results than I expected.
  • Now matter how you solved this, even *deleting* all the nodes and buttons still has the dress shut after simulation like glued.
  • felisfelis Posts: 6,147
    I don't know if you are talking about the above dress or in general.
    But check that the buttons are set to Visibility in Simulation to Off.
  • This particular one. That's what I did, even removed them, still the two sides cling like glued.
    I don't have it.
    Try to show a screenshot of your scene tab with the dress expanded to include the buttons.
    And also try to add a dForce weightmap to the dress, and select that in the scene tab, and select weightmap tool, and in Tool Settings first click add map and then select the weightmap, and show an image of your viewport. The dress should have turned rec-blue-grey (showing the weights).
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,583
    that dress has an unbuttoned version though, wouldn't you use that one?
