Victoria 4.2 Clothing not loading
untuned20untuned20 Posts: 16
I bought Victoria http://www.daz3d.com/victoria-4-2-base
I also bought: http://www.daz3d.com/high-elf-defenders (And it's required items).
I am having an issue, when I try to place the item on victoria, nothing happens. What am I doing wrong? Why won't it load?
  • AJ2112AJ2112 Posts: 1,417
    edited December 2014
    Hi Friend, make sure you have V4 selected in Scene tab. Can you post up screenshot of what your trying to load.
    Post edited by AJ2112 on
  • untuned20untuned20 Posts: 16
    It is selected....
    1920 x 1040 - 387K
    Post edited by untuned20 on
    Hmm ? Did you try loading the Tunic shirt without V4 ? or start a new scene, and just load Tunic shirt or other content in the folder ? Process of elimination. One time I had a similar issue, I uninstalled all the content, re-installed. It work'd.
    I have tried using Genesis, and Genesis 2 still doesn't load. I also Uninstalled the package and it's dependencies, reinstalled, and still nothing.
    High Elf Defenders is a texture set. You need to load the Cloak and Courageous pieces first (the req'd items you bought). Then use the textures on the clothing.
    The actual clothing will be located in Poser Format > Library > Character
    Post edited by Lissa_xyz on
    Ahh, ok! How did you figure that out might I ask?
    How did I figure what out? That it's a texture set or that a texture set won't load the physical clothing?
    To the first, I've seen it enough times, and it says it in the product description. To the second, I've used Poser/DS long enough to know that's how textures work. lol
    I was just curious as to how you knew it was a texture and not a wardrobe item, accessory, prop, etc.
    The 2nd paragraph in the description starts off with
    This highly-detailed texture set for the Courageous package...
    Also, in the What's Included section:
    Features
    A Fantasy Elven Texture Set for:
    Courageous
    V4 Morphing Cloak and Cape
    V4 Hooded Cloak
    Very cool, Vaskania to the rescue. Was thinking the same. Happy all is working.
