Victoria 4.2 Clothing not loading
I bought Victoria http://www.daz3d.com/victoria-4-2-base
I also bought: http://www.daz3d.com/high-elf-defenders (And it's required items).
I am having an issue, when I try to place the item on victoria, nothing happens. What am I doing wrong? Why won't it load?
Hi Friend, make sure you have V4 selected in Scene tab. Can you post up screenshot of what your trying to load.
It is selected....
Hmm ? Did you try loading the Tunic shirt without V4 ? or start a new scene, and just load Tunic shirt or other content in the folder ? Process of elimination. One time I had a similar issue, I uninstalled all the content, re-installed. It work'd.
I have tried using Genesis, and Genesis 2 still doesn't load. I also Uninstalled the package and it's dependencies, reinstalled, and still nothing.
High Elf Defenders is a texture set. You need to load the Cloak and Courageous pieces first (the req'd items you bought). Then use the textures on the clothing.
The actual clothing will be located in Poser Format > Library > Character
Ahh, ok! How did you figure that out might I ask?
How did I figure what out? That it's a texture set or that a texture set won't load the physical clothing?
To the first, I've seen it enough times, and it says it in the product description. To the second, I've used Poser/DS long enough to know that's how textures work. lol
I was just curious as to how you knew it was a texture and not a wardrobe item, accessory, prop, etc.
The 2nd paragraph in the description starts off with
Very cool, Vaskania to the rescue. Was thinking the same. Happy all is working.
