Adding to Cart…
Working on some of the background elements. This is the lodge. The model was downloaded from 3Dwarehouse. This model only occupies about 4% of the complete image so I had to exaggerate the bump mapping to give it a little texture due to its distance from the camera. It's a little rough and unfinished at this size but none of that is noticeable when its 1 inch across.
Love the fox and how he's sniffing the air, it creates the illusion of that winter air smell in the image. So cool!
Is that dynamic fur or trans-mapped geometry or some other form of hair? I think it might need some highlights or translucency - it seems to dark at the moment, I think. Or it might be my screen maybe?
That lodge looks very impressive. I think your image is going to make me want to spend Christmas in the mountains... You are creating a de facto ski resort advertisement, aren't you? :)
Antara,
I have a problem with the size required.
Q: if I want to be near 2000 pxl width, what is the maximum size for the height ?
I was a donkey in the school !:P
Sorry for all the size confusion.
So, if you width is 2000, you have the following options:
2000w x 1533h
2000w x 1548h
2000w x 1020h (or 2000 x 1021, depending on how you choose to round it off.)
EDIT: if you want to get really precise and don't care about the exact 2000px width, you can go with these numbers:
2010w x1541h
or
2015w x1560h
or
2157w x 1101h
Thanks.
I see your EDIT precisions but, the maximum size for the forum is 2000pxl, it isn't ?
Foxy there is pretty strongly backlit. I'll brighten things up a little in postwork, but it's going to be a little blue-cast and dark.
I decided foxy might get hungry, so I modeled him a mousy snack:
Thanks Antara, funny you should say that; I've been tempted to use the big patch of blue sky to put a "Winter Powder is Here! Come Ski..." message but I'm a little worried it might take away from the rest of the image. I'll know after I dust off photoshop and play around a little :)
I found a quick way to give my guys pants some wrinkles using the water shader in the bump map channel.
oops, yes, forgot about that.
Well the first 2 have the precise values available in just a bit under 2000 pixels:
1980w x 1518h
and
1984w x 1536h
But the third one is really tough because it's a prime number ratio of 719w x 367h. Therefore, the only exact whole ratio under 2000 is 1438w x 734h. Which is not even close to 2000, so for that, you'd have to use the approximated one anyway.
Once again, that's a brilliant method you've come up with there! :wow: It probably wouldn't work with all UVs, but I suspect it can be tweaked to work with most.
Thank you! Another cool trick that would never have occurred to me...
Nice trick! I may have to try and animate that effect to see how it looks.
Awesomely cool trick, and it looks very realistic. Excellent tip!
Thanks Antara, evilproducer and Jonstark,
I do think it's application is fairly limited as wrinkle maker and it will only work under certain conditions before the wave pattern becomes too obvious. There are 3 wave generators so with some experimenting one could be used out of phase with another to try randomize the wrinkling a little more.
I've added some rocks to the lake shore because the transition into the water was looking really abrupt (even from up on the mountain). For the rocks I used "Flinks Instant Meadow 2 - Stones" and did some modeling on them for some randomness since I was duplicating the base model along the shore.
I also picked Howie Farkes' incredibly well constructed Spruce 1 tree from his Valle Alpina for my shoreline trees. I played around with the leaf shader to try get a more dry winter looking tree. I also added a parametric mapping shader across the leaves in an attempt to give the trees a light dusting of snow look since they are at a lower elevation. For this is used the noise shader in the Alpha channel to make the white color channel splotchy. I don't know if I really achieved exactly what I was going for but I did manage to quadruple the rendering time!
You really are pulling off some innovative tricks that work well - thanks for sharing :)
I'd be interested in how you did the big blobs of snow on the trees in your first post - are they carefully placed meshes, or another trick ?
Thanks Roygee,
Those were from the "Flinks Conifer" product. I don't think I would have the patients to model something like that!
I just tried to see if creating a mesh ball with a soft cloth modifier with the internal pressure turned up would drape over the branches to create that same effect and inadvertently discovered the fastest way to exit out of Carrara. :ohh:
Thanks Roygee,
Interested,, what was the poly count doing it that way?
Hi chohole,
The ball only had about 100 polygons. The tree was a generated tree so I'm not sure how to see how many polygons or if that is even applicable. It did have a very complex branch/leaf structure and I'm pretty sure that is over the line when it comes to the cloth physics math.
Hi chohole,
OK thanks
Hi chohole,
Since it sounds like it is a Carrara tree/plant it uses a replication system for the branches and leaves which may have had more to do with the crash than the poly count.
Yesterday I became really tired of waiting 2 hours every time I just wanted to see how the little area at the bottom of my render was going to look. My production frame is not the same dimention (way smaller) as my final render and way to often quick render vanishes right after it's done rendering.
So last night I built a little tool to mask out the camera production frame leaving a spot open for rendering. It has 4 morphs to adjust the unmasked area. These let you adjust the left/right and up/down positions as well as two to adjust the size of the hole in the mask. Once you have scaled the tool to your production frame (making it larger to account for the border of the tool) you can drop it onto your camera so that it remains in place while you pan around your scene.
Click to download (www.sharecg.com)
Hi chohole,
Yeah, I totally agree. Generated trees are extremely complex data objects. I must say though, there are plenty of times that I'll do something crazy (like this attempt was) and I'll be thinking "ok, there's no way this is going to work" and then it just does. I am constantly amazed at the depth there is to Carrara. For the most part I do believe that our imagination is the biggest limit.
I agree with you! There's things I've done in Carrara that I thought wouldn't work and they did! Carrara still has stuff I'm learning, and even though I've been horrible about posting in this challenge so far, you guys are giving me plenty of things to try when I have more time!
Thanks for sharing that! I've read of the masking trick before, but have never tried it myself.
Here (again) a version of my wip.
I read the rules of Antara yesterday and asked for some details concerning the formats of images.
I'm not happy for the additional work, but my character thanks Antara because in my previous models, it didn't have shoes (Brrrrrr .....).
I builded some to him and he's happy now.
I worked over textures again and add some elements in the scene and also had to work the ground a little more, approximately 131.000 polygons, soft resolution on 3 = 1 selection click for waiting five minutes minimum !
Sunday is the only day which I can work on this project, fortunately , we have long period this time !
I still think about some details, but I would like your opinion before that.
The title will be: the last sun (of the year), because afterwards, it will be the polar night…
Thank you.
I scrapped the idea of a blizzard - the context would be wrong - a wolf would be under shelter, not baying at the moon! :)
Added some cloud on a surface replicator. To get around the problem using volumetric clouds with the transmap on the Aurora Borealis, I did a render, put that in the backdrop, added the clouds and rendered.
The only post-work I'll do will be to clone the sky over the background rock to give the wolf a better silouette, so I guess this is the last WIP for this entry.
I still like the idea of a blizzard, so am planning another entry. This needs quite a lot of modelling, so I hope to have enough time to finish :)
Is that wolf wearing a cape? Because Super Wolf would not be afraid of a blizzard. ;)
Now there's a thought....the goggles and speedo shouldn't be a problem, but dunno if I can manage the tights :)
Good luck with the animation! Creating an animation in under 15 days is quite a tall order.
But, I hope it will leave you enough time to finish your entry before the 24th.
I am intrigued by your Chickenman and Lady concept, and I want to see what you had in mind for the entry.
Well she got her spaceship modeled in Hex on the weekend now she will set up the shader domains in Hex then into Carrara she comes.
She is doing the actual shaders in carrara as well as the animation and rendering. She used Hex as that is what she as played with before so kind of knew.
She is trying to keep it somewhat basice due to the time. She will expand it depending on time left.
She is looking at doing a fly by kind of like the begining of Star Trek Voyager.
For the star background she will use Dart's Starry Sky
I have built a new computer for this so that will also speed me up as well.
I have watched some more of Phil's video's to assist her and help me with the challenge.
She has used DAZ Studio for the last 3 years and is fairly good at it so Carrara is a good step for her as in the fall she wants to go to college for 3D animation to start her career.
I now know how to do my own landscapes and a little bit about the replicators so I may be able to include them as well.
We will see where my scene will take me.
Hopefullly I can get mine done.
Here's the start of my second entry - Some say he's a wondering poet, others call him a homeless bum - we know him as the Pilgrim!
At the moment he's stuck in a cave during a blizzard :
What I've done so far - posed M4 and exported as .obj and modeled everything else in Hexagon. Did the cloth drape in Blender and the UV mapping in UU3D.
Still to do - hair and lots of it - on the cloak, boots, beard as well as on his doggy companion, still to come. Make a fire and a blizzard.
I'm going to try for monochrome, so will need to do some serious "painting with shadows", as Dart says.
