Removing M4's facial hair
VicS
When clicking a beard from 1 Click M4 Face Hair the original faical hair is not removed, is there a way to remove it but still keeping M4 original skin?
Which set it is that? Undo or reapply the base materials, I suspect - these will be Poser-compatible products and it doesn't have a Layered Image Editor.
1 Click M4 Face Hair is the name of the product, it says it had been tested in daz,
normally M4 defualt beard will be removed when another is applied?
Undo or reapply the base materials if this is this what I should try? how is this done please
Because the OP refuses to link the actual product:
https://www.daz3d.com/1-click-m4-face-hair
https://www.daz3d.com/1-click-m4-face-hair-for-poser
Thank you, it is this one https://www.daz3d.com/1-click-m4-face-hair
OK, that is a Daz Studio product. Reapplying the base materials would still be quickest, but you could also open the images affected in the Layered Image Editor (in the Editor tab of the Surfaces pane select the Face surface on the left, then click the nano-thumbnail for the map to the left of the property slider in question to open the image menu and select Layered Image Editor) and deleting the unwanted layers.
If only I could select the facial hair then it can be lowered in opacity surface tab but does anyone know how to select the hair, it is not in the scene tree or found under surface tab with M4 head selected, if anyone knows any way to reduce the product's facial hair opacity please let me know, thanks.
Merged threads.
As in my reply above, open the Layered Image Editor but this time adjust the layer opacity rathan fully deleting it.
OK thanks Richard
Your suggestion worked, thanks Richard
