Glass shader settings
SteveM17SteveM17 Posts: 1,061
I've added a shader to some glass in a window. When I render the figure behind the glass is distorted. What setting in the surface panel do I alter to lessen or get rid of this distortion? Below is an example.
Cheers.
  • FishtalesFishtales Posts: 6,244
    If in Iray then use the Thin Glass clear shader.
  • prixatprixat Posts: 1,630
    It looks like the refraction is quite high.
    If you want to keep a hint of the distortion then reduce the IOR (index of Refraction) to a value nearer to 1.
  • SteveM17SteveM17 Posts: 1,061
    It's not in Iray, it's 3delight.
    Messing around with refraction seems to be the solution as you suggest. Thanks.
    That isn't distortion, those are broken panes of glass so some of the character is behind glass and some not so it looks like distortion.
    Here is a render with less refraction, but the glass doesn't look convincing to me.
    1860 x 867 - 756K
    edited January 2016
    With a dark room behind the window, I would expect glass to be more reflective.
    Do you have something for it to reflect?
    Post edited by prixat on
    You mean something behind the camera? No, it's empty at the moment, but I'll add something and see if that works.
    The Refractive Index for glass is usually 1.50 but can vary by type.
    At the moment the index of refraction is at 1.45.
    I've put a building across from the window, but can't get a reflection for some reason.
    Is there any light source illuminating this new building? You might need to add one, or adjust your existing lights.
    I thought of that, and put a spotlight bang in front of it. Still no reflection.
    edited January 2016
    How about something closer to the window?
    If you move the bat a bit, does it reflect?
    Though you get into tough philosophical questions like, "If vampires don't have reflections, why would do vampire bats have them?"
    You have hurt my brain.
    Is there any way to remove a shader?
  • Apply a different shader.
    I mean is there a way to make an object go back to simple diffuse type settings, as it was before any shader was applied?
  • That is the Daz Default Shader - you could make a preset, if one isn't supplied, by saving a Shader preset from a newly created primitive.
  • Mage 13X13Mage 13X13 Posts: 456
    edited January 2022
    Actually its 1.52 for clear glass with white light. Other light colors change this because of the difference in light wave lengths. Different colors have different wave lengths. You are correct that there can be other values for glass depending on composition of the glass, though. Leaded Glass actually has a higher index.
    In  Surfaces go to the Presets pane and select Shaders. Find Utilities in the list that comes up and open it. At the top of the items in that section you will find the first one is ! Reset Surface. That will remove everything, and set your surface back to untextured. Hope this helps.
