two poses in one animation
I would like to use two individual poses in an animation and the foot should be frozen. How does it work?
Which foot? What problems are you having using two poses at the moment?
If you mean keep the feet on place, just use MCasual's AutoLimb, just google it and you will find his site. I use it on daily basis, works great paired with the HoldOn script which makes a specific part keep its orientation or follow another object's one.
the problem is that when moving from one pose to another, the standing leg makes a parabolic movement from the initial pose to the next pose.
You are unlikely to get good results just setting a couple of poses, you will almost certainly need to set at least one or two intervening keys and perhaps to adjust the interpolation too.
Thanks for your reply. I've already tried a lot: set a couple of poses, set interpolation: TCB, Linear and Constant. Nothing works. I will try with the HoldOn scriptю Thanks
