two poses in one animation
I would like to use two individual poses in an animation and the foot should be frozen. How does it work?
  • Which foot? What problems are you having using two poses at the moment?
  • ImagoImago Posts: 5,798
    If you mean keep the feet on place, just use MCasual's AutoLimb, just google it and you will find his site. I use it on daily basis, works great paired with the HoldOn script which makes a specific part keep its orientation or follow another object's one.
  • Redner63Redner63 Posts: 6
    edited January 2022
    the problem is that when moving from one pose to another, the standing leg makes a parabolic movement from the initial pose to the next pose.
    You are unlikely to get good results just setting a couple of poses, you will almost certainly need to set at least one or two intervening keys and perhaps to adjust the interpolation too.
  • Thanks for your reply. I've already tried a lot: set a couple of poses, set interpolation: TCB, Linear and Constant. Nothing works. I will try with the HoldOn scriptю Thanks
