Most Spectacular Teeth and Tongue and Inner Mouth ?
Fauvist
In your opinion, which character, figure, or product has the best looking TEXTURE/SHADERS for Genesis 3/8 teeth, tongue, gums, and inner mouth - for Iray. When I was using 3Delight I had this product called Exciting Mouth - that I used all the time. (I don't need new teeth or tongue models - just great textures/shaders.)
Thanks!
Post edited by Fauvist on
so .. I misread that as exiting mouth
can you use the textures still?
if not for G3&8 map transfer will work if you have Caymans UVs
Redacted
Exciting Mouth, but not for Iray. The moistness of the tongue and gums really adds to it. Something like this for Iray? CHWT and cridgit - I'll check out Maxx and Kate. Thanks.
That looks really good. It might work for male figures. I'll buy it and try it. Thanks for pointing it out to me!
I regularly go edit the surfaces by hand. Add more gloss to the mouth, lower translucency for teeth (and mouth). Sometimes even use diffuse overlay to brighten the gums and tongue a bit. I do find that most g3f and g8f textures out of the box have overly dark mouths (for fairly light skinned models). Also, when I find one I like I reuse it with other models as well...
