How to see the furniture from the outside of the house?
kyoreona
I've recently noticed some products that have some really cool features. For example, under the operation interface, the outer wall of the house is transparent, and the furniture inside the house can be seen from the outside. That's very interesting. How do you do that?
DAZ products?
I know an Xray feature in other software but not seen this myself in DAZ store
Adjust the opacity of the surface and/or apply a transparency image to the cutout dial.
Of course.
can you maybe link the DAZ products showing what you are talking about
(what I meant to ask as not seen any)
Did you put a solid Black/White transparency image on the concerned surface of the target model?
If it is a separate bone or prop, select it and go to the Parameters pane where you can turn off Visible In Viewport (under Display)
You do realize that many a "room" in television land does not consist of 4 walls. One hides, removes from the scene, uses transparencies, etc. to make things invisible in the scene.
I'm not aware that anything in Daz Studio will do that, except posibly using a rendered-preview with a custom sahder that treats the two sides differently.
You could parent an iray section plane to the camera, and that could sort of get the effect you're looking for.
