How to see the furniture from the outside of the house?
I've recently noticed some products that have some really cool features. For example, under the operation interface, the outer wall of the house is transparent, and the furniture inside the house can be seen from the outside. That's very interesting. How do you do that?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,639
    DAZ products?
    I know an Xray feature in other software but not seen this myself in DAZ store
  • kyoreonakyoreona Posts: 222
    DAZ products?
    yeah,daz product!
  • Adjust the opacity of the surface and/or apply a transparency image to the cutout dial.
    Does this affect the final render result?
  • Of course.
    Of course.
    No, it's only transparent in the interface, but it's still opaque after rendering.
    can you maybe link the DAZ products showing what you are talking about
    (what I meant to ask as not seen any)
    edited January 2022
    kyoreona said:
    Catherine3678ab said:
    Of course.
    Did you put a solid Black/White transparency image on the concerned surface of the target model?
    Post edited by Catherine3678ab on
  • If it is a separate bone or prop, select it and go to the Parameters pane where you can turn off Visible In Viewport (under Display)
    1402 x 1034 - 151K
    Thank you for your answer, but I know that. I'm talking about situations like the following. There is a person in the room, drag the view outside the room, the wall blocking that person will automatically become transparent. The other three walls are opaque. It's a dynamic process. Maybe I have to find that product before I can explain it to you.
  • You do realize that many a "room" in television land does not consist of 4 walls. One hides, removes from the scene, uses transparencies, etc. to make things invisible in the scene.
    I'm not aware that anything in Daz Studio will do that, except posibly using a rendered-preview with a custom sahder that treats the two sides differently.
  • SpaciousSpacious Posts: 481
    You could parent an iray section plane to the camera, and that could sort of get the effect you're looking for.
