finding v4 and m4
VicS
I just installed [v4 and m4] them both but cant find either- thanks for any help
VicS
the Victoria 4.2 Base and M4 base
Go to the Poser library.
where specifically I did look there already all over , thanks
If you installed M4 and V4 via DAZ Install Manager, then it is easy to find.
Launch Daz Install Manager (DIM).
Enter into the search field what you are looking for. In this case victoria
Now click on the installed tab
Now find the Victoria item you are looking for in the list of props, figures, etc.
And then right click on the selected item and chose "show installed files"
And it will show the directory path to where the selected item is installed, including all of it's support files, textures, etc.
thank you, i installed it is installed through IM, can you tell me exactly where t look, i mthyink ive looked everywhere
Kindly refer to my posts & images above. Click on the images to display them at their full resolution.
thank you, i did locate them IM can not find them anywhere within daz though
can you also please tell me how to post an image here as you have done, thank you
IM is informing you WHERE they are located in your file structure which in DAZ you have defined as the location of your Daz content.
To post an image you click the Attach a file at the bottom of your post.
Content Library tab, Poser Format directories, Figures > DAZ People
ok thanks!!
