finding v4 and m4
VicSVicS Posts: 1,273
edited December 2021 in Daz Studio Discussion
I just installed [v4 and m4] them both but cant find either- thanks for any help
  • VicSVicS Posts: 1,273
    the Victoria 4.2 Base and M4 base
  • AscaniaAscania Posts: 1,856
    Go to the Poser library.
     where specifically I did look there already all over , thanks
  • kenmokenmo Posts: 1,235
    If you installed M4 and V4 via DAZ Install Manager, then it is easy to find.
    Launch Daz Install Manager (DIM).
    Enter into the search field what you are looking for. In this case victoria
    2520 x 578 - 58K
    Now click on the installed tab
    2513 x 991 - 262K
    Post edited by kenmo on
    Now find the Victoria item you are looking for in the list of props, figures, etc.
    And then right click on the selected item and chose "show installed files"
    3840 x 1440 - 575K
    And it will show the directory path to where the selected item is installed, including all of it's support files, textures, etc.
    1796 x 1051 - 390K
    1796 x 1051 - 390K
    thank you, i installed it is installed through IM, can you tell me exactly where t look, i mthyink ive looked everywhere
    Kindly refer to my posts & images above. Click on the images to display them at their full resolution.
    thank you, i did locate them IM can not find them anywhere within daz though
    can you also please tell me how to post an image here as you have done, thank you
    IM is informing you WHERE they are located in your file structure which in DAZ you have defined as the location of your Daz content.
    To post an image you click the Attach a file at the bottom of your post.
    1280 x 554 - 129K
  • BejaymacBejaymac Posts: 2,009
    Content Library tab, Poser Format directories, Figures > DAZ People
    ok thanks!!
