UV Map looks like a patchwork of the UV Map
Having a lot of trouble figuring this one out. Made the UV maps in CLO3d and trying to use them in DAZ. Any suggestions?
It should just be a green velvet dress, but it is a copy of the UV map.
Thanks for any help.
Sid
It's set to tile - check the Editor tab of the Surfaces pane with the dress and its fabric selected, the Tiling values should both be 1 and the offsets 0 since this is a non-repeating texture (you might use a higher value if you had a texture that was a small piece of fabric and it joined cleanly at the edges of the image).
Thank you Richard, I am sorry I just now am seeing this because it is an issure for me again. I checked both the tiling values and offsets and they are as you suggest 1 and 0 respectively. I appreciate your suggestions and your taking the time to reply. Sid
Don't forget that if this is using one of the default Daz Iray shaders there is also a per-image tiling option, click the micro thumbnail next to the colour property and select Image Editor (rather than Layered Image Editor) in the menu.
