2014 Holiday Season Carrara Challenge (#14) - WINNERS ANNOUNCED - WIP Thread
1568101117
  • pimpypimpy Posts: 274
    pimpy said:
    "Winter... Christmas is coming"
    Here my render preview
    That scene looks like it will be a fun one!
    Thanks EP and many thanks for your adivice about irradiance map. I used it for my new render and my cpu's pc said thank you!
    MDO2010 said:
    I wasn't totally happy with the hair texture on the head of the woman so I thought I'd add a little bit of Carrara hair at a low hair count just to look like random fly-away hairs. This is my first time using Carrara's hair... why did no one tell me how much fun it is? I just spent 40 minutes cutting and brushing hair around. :)
    I love it for still images. Not so much for animations!
    Glad I could help! :)
    I think I'm pretty much done.
    I played with the color on the lights a little, added a background gradient to get little color in the sky and added some lens flare to the streetlights. Also - I learned something interesting: don't do a depth pass with a volumetric cloud covering three-quarters of your scene because it will all show up as one single depth. :( I had to hide the cloud and re-render just the depth pass. Fortunately on the second render all I needed was the depth pass so I could turn off all the lights and it rendered like lightning. :)
    Postwork: de-saturated the whole image slightly, fixed some lighting issues caused by my textures, fixed a little bit of poke-through on the woman's hair, used the depth pass to add some lens blur, darkened the edges and added signature.
    Here is the final render and the post-worked version.
    Mark
    2000 x 1533 - 575K
    2000 x 1533 - 447K
    Very nice job on that scene. Love the little hidden details, such as the signage. I think it was a great idea to add a color gradient to the sky.
    BTW, just for folks that may not be aware of it, anything you use in the scene's Background (not Backdrop) will be treated as an Image Based Light (IBL) similar to an hdri if the skylight is enabled in the Render Room. The Realistic Sky under Atmosphere is also treated as an IBL, but did you know that you can use both the Backdrop and the Realistic Sky together?
    edited November 2014
    I tried an experiment to get snow on my rock outcrops aside from what I could get from the procedural terrain shaders.
    I built the rock outcrops as vertex objects, so what I did was to select polygons in the flatish areas where I wanted deep snow, and copied and then pasted. This created a separate polymesh. The displacement painting that I had done on the outcrop was eliminated from the pasted polymesh, which was good for my purposes. I then used soft select to manipulate the mesh to bulge it up or push it in to hide the edges.
    I also selected the entire separate polymesh and created a new shading domain for it so I could add a snow texture.
    755 x 572 - 280K
    863 x 941 - 141K
    595 x 412 - 279K
    848 x 677 - 363K
    986 x 926 - 650K
    So here's a couple test renders of the added snow.
    Next up, icicles. The challenge with the icicles is that these aren't like what hangs off the eaves of your roof in the winter. Many times there are small gullies that channel melt water to specific points and it looks like a frozen waterfall. Usually there are also small springs that can provide enough water to make an ice fall. What I need to do is find some logical or nearly logical places for that to occur and balance it with my final framing of the image. Not to mention, I need to be able to effectively model them. I think this is where modeling in the Assembly Room will come in very handy!
    1200 x 800 - 752K
    1200 x 800 - 860K
  • StezzaStezza Posts: 9,162
    After some positioning and texturing I have done a draft render..
    made some tinsel, a melted snowman a washing powder box with flakes which still need texturing.. also used emoji fella with a textured plane to represent the sun...
    The koala is causing me grief with posing and need to fix that...
    Struggling on during the northern winter heat.. only 31c today.. a lot cooler than what the weekend was like.. which peaked at 45c in some places!
    900 x 658 - 305K
    Post edited by Stezza on
  • stringtheory9stringtheory9 Posts: 411
    This happened while futsing with hair... Elvis has left the lodge!
    800 x 600 - 28K
    I switched to the "3) Final Trim: 45.875”h X 89.875”w" size option to reclaim some lake view. I'm also playing around with tree placement. I need to re contour the foreground snow on the lower left so I can plant some trees around the lake shore.
    Modeling and texturing on the jacket is finally complete! I've got to give the poor guys some glove though. Next I need to work on some ski trails in the snow behind him and then deal with that snow spay which I've been putting off.
    1582 x 800 - 248K
    Post edited by stringtheory9 on
  • AntaraAntara Posts: 444
    I'm sorry I cannot post comments today.
    But I want to let you all know that the final entris can now be posted to the Entry thread here: http://www.daz3d.com/forums/discussion/49155/
    Post edited by Antara on
  • Bunyip02Bunyip02 Posts: 9,314
    G'Day Stezza
    Any chance of a Platypus sticking it's head out of the ice water in the Esky and holding up a stubbie for the Kangaroo ?
    Looks like it's going to be a hot one down-under this summer !!!!!!
    Regards, Bunyip
    Final view ...(I hope)
    size
    Final trim 2000x1533 = ratio 60" x 40"
    Live area 1900x1433 = ratio 57" x 43"
    Comments are welcome :)
    2000 x 1533 - 2M
    Hi stringtheory9,
    I like your render! The full composition and the lighting but if I were you should put a bit of snow on the trees ... but this is my opinion ...:)
    Mark
    Hi MDO2010,
    Looking this picture " brrr" I feel cold! I like the atmosphere of the full scene and of course fhe ligths on the trees. very good!
    Post edited by pimpy on
  • RoygeeRoygee Posts: 2,247
    @stringtheory9 - as I posted previously, this is really great work:)
    I would consider some change to the placement of the trees - the upper body detail tends to fade into the trees.
    Perhaps some change in lighting to make the figure stand out from the background? Possibly if you put the snow back on the trees, this would serve the same purpose?
    I really love the sense of action :)
  • VarselVarsel Posts: 574
    Here I'm trying to combine the two elements together.
    I think I have to do something to get the lady to be more prominent.
    What about some kind of impractical armour.. %-P
    There is still some chains to create, and a summer-bear to fur up.
    I am also considering to put in some fog or cold windy clouds.
    I am also going for option number 3
    Live area: 44.875”h X 88.875”w
    Any thoughts and ideas are more than welcome.
    1177 x 600 - 775K
  • DUDUDUDU Posts: 1,945
    Varsel,
    I like a lot this concept!
    If you want my idea, there should be a softer transition between the two seasons.
    I would also like to see some vapor who come out from the mouth of the bears.
    Nice work !
    Post edited by DUDU on
    Hello Varsel
    Excellent concept, and very nicely put together as well !!!!!!
    My 2 cents worth......
    Transition - as snow normally falls, instead of fog maybe snow falling down over the snow scene including that section
    (maybe 2 metres/6 feet) just in front of the snow that the polar bears are standing on.
    For the lady maybe an ice-blue color, not so that it stands out like a sore thumb, but just enough color to get that difference.
    Alternatively she could be projecting an ice-blue aurora/halo around her, she could also be projecting out an ice-blue energy bolt from her raised hand "Out of the way Autumn - Winter is here and I'm coming through".
    Have included a DAZ render I did a while ago to give you some ideas about an ice-blue tinge.
    Everyone so far keep up the great work !!!!!!!!
    1950 x 1424 - 7M
    Hi Varsel,
    Woderfull idea and very nice composition. I love it!
    (p.s. DUDU's advce is a great idea ....)
    I forgot this... :cheese:
    to realize the light on top the tree I used a bulb with two effects: Cross Screen, and stars, and these are the settings
    1920 x 1200 - 757K
    G'Day Stezza
    Regards, Bunyip
    I had the strangest feeling that someone was looking over my shoulder.. lol
    I've been slowed down a bit with issues within 8.5beta... :-(
    I like your thinking... I made a stubby holder but getting the platypus in an ideal pose is hard... had to just get him relaxing in the esky :-)
    Here is a test render on my WiP which is nearing completion..
    800 x 613 - 439K
    We call, those coolers and if they're made by a certain company, Igloos. Is Esky, slang for Eskimo?
    yep...
    Esky is an Australian term for "portable cooler".
    The word "Esky" is in fact a brand name produced by the company Nylex. The term originates from the word "eskimo" for its cold connotations.
    Its popularity has become so great during the years that the brand-name has now been used to describe all types of portable coolers whether made by the Esky Brand or not.
    You always take the esky on a picnic or to the cricket... ;-)
    Stezza said:
    yep...
    Kind of like Igloo here.
    This is my final render before I do some post work
    I've added some more elements
    some droplets & splashes.. a railway track, a visit NYC sign a cactus and the obligatory black stump.. as this render is beyond the black stump!
    Must say, I had fun doing this winter [cough cough ] render challenge :-)
    [click on image for bigga version]
    1306 x 1000 - 1M
    This vintage promises to be exceptional, very goog work everybody !
    It is certainly the magic of the winter which revives the creativity…
    Here an evolution of my project.
    I worked over the costume again and created some more elements in the scene.
    The terrain was also re-worked, I modified a part with the displacement painting tool around the tent (lavùù, in Lappish language).
    I have difficulty with the lighting to recreate as well as possible the atmosphere of this moment of the day, I will still test other adjustments.
    I am very impressed with the improvements and especially with the snow terrain you have created. The way it has different areas and different levels of being trampled on - wonderful! The scene is coming together beautifully. And I like the latest version of the lighting.
    A possible thing to tweak a bit is the right arm pose of the figure. It could be just me, since nobody else said anything, but I have difficulty reading his gesture. I know he is pointing, but his arm is at a weird bend and I can't quite figure out why.
    Q. in the hair room, wath is the " Convert" button beside the "drape button " ?
    After you drape the hair, the guides will remain as they were (or they should). The button converts the guide hairs to the relaxed/draped shape, so that the hair can be modified through the guides after it was draped.
    That is one amazing unusual landscape. It's amazing how much colder it looks with the ice on the river (Great ice shader, by the way!) I think the added snow geometry works very well, adding more realism, especially where it partially covers up dried up plants and on the river ice. usually snowy images look like fun and games to me, but you've managed to show the dangerous side of winter. Somehow that landscape is both beautiful, but very unwelcoming. So I agree with David - it makes me shiver too.
    Good luck with the icicles! It sounds like a fun challenge for a long evening indoors :)
    Antara,
    I'm really sorry to hear that you are having back problems. I hope that they figure it out and you find relief soon!
    Thanks you! The jacket in the close up image is the Daz product "Adventure Jacket". I was using it as a stand in (it has a nice clean UV map) while I tried different textures to see what they would look like in place. I'm still trying to figure out the whole UV mapping thing to apply the texture to the jacket I modeled. I'm using photoshop to piece together bits and pieces I've pulled from the web. The modeling is all done in the Carrara modeling room. Besides adding walls to existing models the goggles are the first actual object that i've modeled. I used the curvey line tool to create the shape of the lens and then duplicated that and extruded the frame (pretty much the only two tools I know how to use at this point). Same process for the skis.
    The jacket I'm working on started as a sheet with a hole in it which I draped over M4 and then bent and tweaked with the soft selection tool. The sleeves started life as polygon rings with I extruded and then pushed and pulled into shape. I'm sure there are better ways of going about it but right now I'm just fumbling my way through. lol
    Thank you!
    Those are neat creative ways to model things! That jacket method would never have occurred to me. :) :wow: And you are getting very impressive results with it. The goggles look professional,nicely detailed and very cool. See, if you hadn't told us that it's your first modeled object, I would have thought you have an extensive modelling background, and started using Carrara for the convenience of having many elements besides modelling available conveniently in one place.
    You also ended up with interesting hair there! :) Which you then made to look really great in your next image - they add such great sense of speed and dynamic to the pose!
    Wow. :wow: That jacket looks great! Lovely texture Easter egg! :) And yes, the guy does need hands protection . If you don't have ready-made gloves, and don't feel like modelling them, maybe just changing the texture (or messing with the shading domains on M4) will give you the desired effect - we don't see too much of them anyway.
    I really like the new aspect ratio and the the extra space for him to ski down. The wider left-side space with the steep slope give the sense that it's a fun way down, yet a very long one yet. The trees behind the figure also work very well compositionally - both drawing our attention there and through their vertical lines visually accelerating the movement.
    About the glowing snow powder: Can you render your image with the multi-passes?
    because if you can, you will get 2 separate layers for the fire primitive: Volumetric Add and Volumetric Multiply. You can then play with the settings on those layers to control how much they contribute to the final image (for example, reducing the opacity of the "Add" layer can lessen the glow effect.)
    Sorry to hear about your back pain. That can't be fun. Hopefully, you and your doctor can figure that out.
    Thanks for the kind words. The fur came out very nice even though I didn't properly map the objects I used as bases. Worked anyway. :)
    I still haven't thought of a good title for this one.
    And no, no second image from me. Don't tempt me. The last two Challenges have been like shiny objects, distractions. Very enjoyable distractions. :) But, I do have projects I need to finish, and the Thanksgiving holiday will be the prefect time to set my nose to the grindstone. (Ouch!)
    Thank you, David. :)
    Good luck with the title! :)
    Pity abut the second image... it was worth the try though :) I feel your pain with having projects to finish. I have one due by the end of the year with ~15 images, which I haven't started yet, and now my back isn't letting me... Moral of the story: Please be kind to your nose! :)
    And stop by this thread when you feel like resting and having some fun :).
    Also, the Entry thread is up and running, so you can post your finished entry there:
    Welcome to the secret society of those in the know about the hair room! Whenever I do things like hair and fur, I have to set up alarms so I remember to eat or get up occasionally. (No wonder my back is out of whack....) I get really carried away with it. Sometimes having fun, other times getting frustrated out of my wits because there is that one hair that won't bend properly no matter how many guides you plant right on top of it... >:-( look at my eye twitching... :lol:
    I'm happy you are discovering the joys of Carrara hair :)
    Mark
    I like the improvements you introduced.
    Great tip about the cloud/fog, I need to remember that, thank you!
    If you are ready to post it in the entry thread, it's ready and waiting :) http://www.daz3d.com/forums/discussion/49155/
    Love all the animals in there! This image is so much fun already. Such delicious hilarious details. The platypus looks like he's enjoying himself the most. :-) Poor snowman... :( That sun looks really angry.
    And, wow on your weather woes! Those temperatures sound like a natural disaster figures, not a weather report. :( Keep cool! (and render on!) :red: sorry, couldn't resist.
    size
    :ohh: :wow: I love the tighter crop on the composition!!! It's exactly what this image was missing. And the new lighting/snow shader is perfect!
    Also in this tighter crop I feel an instant emotional connection with the figures in the foreground. It's as if we are standing with them on that ledge, sharing that experience. I am completely awed by the huge difference such seemingly simple change has made to this image. :wow:
    Did you render it with altered gamma?
    And thank you for the kind comments and wishes. I mostly feel fine these days on painkillers, but if I spend too much time sitting, it gets worse. So 99% of my computer times goes to my day job... and then I find out I have 3 pages of posts to catch up on here... :)
    That's a brilliant idea for the image and stunningly beautiful execution already! I also love your idea about adding cold windy clouds or fog.
    I would agree with Bunyip02 about adding breath fog to the bears and making the Queen's skin a less gray - more blue shade. The sled metal could be more reflective, I think, same with metal parts on the harnesses.
    If you narrow your eyes and look at the winter side of the image, the thing that stands out the most right now is the white snow, the bear fur and the white top of the Queen's hair. I think whitening her coat might make her figure pop more or adding a white vertical through a whiter dress/sled: something to make her connect more to the snow and the bears, and less to the more gentle trees in the background. I think that will give her a stronger presence and a better sense of forward motion.
    I think the fall forest looks perfect! the only suggestion I might make is about the grass - is it a texture or does it have some geometry? you might want to add some geometry grass and fallen leaves, and that will give you a chance to shade some in fall colors and where there is the winter edge - add the differently frost-shaded grass/leaves to further enhance the sense of moving barrier.
    But the image already works very well, and these are all pretty minor adjustments. I'm loving it already and look forward to the next stages.
    Bunyip02 and Roygee, will you be joining the fun with your own WIPs? :)
    Bunyip02 and Roygee, will you be joining the fun with your own WIPs? smile
    Hello Antara
    Hoping to finish up my current works by the 10th December, if I'm not suffering from "Render burnout" am hoping to get an entry in.
    Will hopefully allow a couple of weeks to get my entry in - already have an idea/concept for it.
    In the meantime I will keep lurking when-ever I can, and add a few ideas when I am able to.
    Latest version of Stezza's esky with the Platypus gave me a well needed chuckle.
    Also reminded me of the time I was lucky enough to watch a Platypus in the wild splashing around a waterhole for about half an hour.
    Still need to finish off last competition's entry as well !!!!!!!
    Regards, Bunyip
    Antara said:
    size
    Hi Antara,
    I'm very glad you're feeling better!
    I thank you for the valuable advice and comments and to answer your question I used a gamma correction to 2.2 for the final rendering and a light post production in Gimp by altering the level of blue
    Thank you : DUDU_00001, Bunyip02, pimpy and Antara
    These are all great thoughts, and will keep me busy.
    So I will keep adjusting, tweaking and re texturing.....
