Colony Hair for G3F on a G8F - not morphing
hi all, in my collection i have Colony Hair for G3F:
https://www.daz3d.com/colony-hair-for-genesis-3-female-s
many of the G3 hair sets i've applied to my G8Fs work without too much trouble, but this one is a little weird - all the morphs are listed but they are all ineffective, i move the sliders, nothing happens.
i realise i am using this 'outside of recommended manufacturer specifications' and am not expecting a fix, but i am curious as to why it happens with this hair set only.
related, the hair does not have a 'behind shoulder' morph so i'm probably going to have to export it out to max and make a custom behind-shoulder version of it (it *does* have a 'blow back' morph - not the same thing) - any advice from anyone who's done similar things before?
i figure i'll need to separate out the front locks and then... soft select and move? bend? i'm not sure which approach to try yet, both have a good chance of mangling the hair in ways i don't want.
did you autofit it? Autofit tends to destroy special morphs. try the scene ident edit method or parent it instead
i used the same 'shoulder length hair' template i usually use, but out of many many G2F and G3F hair set i own, this is the only one i've encountered this issue with
as stated before, it looks like i'm going to have to stick it into 3ds max to get it in the shape i want, but i'm curious as to why this hair alone has ineffective morphs in G8 when all the other G2/G3 sets i have work completely, or mostly so
ok, i'll try that. thanks!
