The Only “Gust” I Like Begins With “Au-” Complaint Thread.
1394042444550
  • kyoto kidkyoto kid Posts: 42,371
    tjohn said:
    TroutFace said:
    Bank run done, got a ride from a co-worker so no screaming in the rain for me!
    Screaming In The Rain
    (apologies to Arthur Freed and Nacio Herb Brown)
    I'm screaming in the rain
    Just screaming in the rain
    What a horrible feelin'
    I'm p*ssed-off again
    I'm yelling at clouds
    So dark up above
    There's hate in my heart
    And no room for love
    Let the clouds disappear
    Just blow out of here
    Enough with the rain
    I want the sky to be clear
    I run down the street
    Beat a hasty retreat
    Just screamin',
    Screamin' in the rain
    ...excellent. I need to adopt this as my theme song.
    ps1borg said:
    Morning. Feels hot and warming up an hour or so after dawn, meanwhile pictures of snow are all over breakfast TV from the US I think (?) making for a contradictory feel to the day so far :lol:
    ...they actually had to move an NFL football match from Buffalo NY to Detroit MI (where they have an indoor stadium) as the stadium in Buffalo is buried under 6' of snow.
  • starionwolfstarionwolf Posts: 3,670
    not really a complaint but I haven't seen this blue artifact on my renders before. The artifact appears randomly. In this render the artifact is on the back of Genesis' head.
    312 x 292 - 30K
  • Richard HaseltineRichard Haseltine Posts: 111,217
    DanaTA said:
    Complaint: Ancient Greek Boats showed up in the product updates section of the DIM. Download failed! I managed to fix that problem by deleting the previous download. Then Install Failed! I looked at the log, deleted the file that it said it could not extract, and tried again. Install Failed! I looked at the log again...a different file could not extract.
    Then I just opened the zip file and started putting stuff where it wanted to go. Then I noticed something. The path was wrong. It starts out with Content. Data, People, Runtime, and Vehicles are all under Content. But Data, People, Runtime, and Vehicles are all actually under DAZ3D Library. Under Content, there are folders for Data and People. So, we still have path confusion amongst our vendors. Do I put them under Content, or directly under DAZ3D Library? I think the latter. It's so screwed up, though. That's probably why the DIM indicates Install Failed! I've had problems like this before. When I contact them about it, rather than try to figure out why, the answer I get is "Just install them manually!" This took me all of five minutes to figure out. Not much effort, and customers would be happy.
    The funny thing is, the files are under a subfolder named dazcontentqa. I'm guessing the qa stands for Quality Assurance. Fail!
    Dana
    DAZ zips always put Poser and DS content in a folder named Content, to distinguish the files from plug-ins or the like. DIM knows not to include the Content folder. If you are saying that the folder in the zip is instead named dazcontentqa that would be an issue and should be reported.
    That's caused by using Deep Shadow Maps. The best fix is to use Ray-traced shadows, but you may be able to avoid it by tweaking the camera angle or reducing the light intensities.
  • DanaTADanaTA Posts: 13,403
    Dana
    But the existing files are in the proper places...DAZ3D Library/Data... DAZ3D Library/People... etc. DAZ3D Library is what used to be the Content folder. And unfortunately, there are still items that create another Content folder under that. There is not a lot in there, but there is enough for it to prove there's an issue.
    Secondly, yes things are being put into a folder named dazcontentqa.
    Dana
    779 x 595 - 81K
    So, KK, is it safe to let the DIM install the new version of DAZ|Studio? I noticed also the Dynamic Cloth Control showed up as an updated item, as well as the Look At My Hair player.
    I wonder what other plug-ins are trashed with this update. These certainly can't be the only two.
    Dana
  • TJohnTJohn Posts: 11,399
    I can verify that Reality 2.5 still works in 4.7. :)
    1250 x 1500 - 251K
    edited November 2014
    Ok, that makes sense. The light sets that Art Collaborations cast deep shadow maps.
    My new complaint is that I cannot buy Millie for teen Josie 6. The store gives me an error message about the payment. I wish I took a screenshot of the error message. Here is the screenshot of the check-out page. I'm going to log out and log back in.
    edit: not trying to complain about the buggy store; the error is probably my fault because I didn't log in properly.
    482 x 463 - 46K
    Post edited by starionwolf on
    Dana
    Dana
    Those are the data files, so they aren't directly accessible inside the application. Specifically Jen Greenlees is in charge of Content QA for the Platinum Club, so when she converts those older Poser-format products to DS, the data files are put under dazcontentqa.
    If you're actually seeing those folders inside DS (as will happen if you have a folder named "Content" inside "My Library", for example), then they won't work properly. If you're finding products that have nested content folders, please submit a tech support ticket to have them fixed. All the products I own have been fixed (Daedalus Peasant for Aiko 3 was the last one fixed, but it has 2 SKU's and the older one hasn't been removed yet, so make sure you install 5227 and not 3983).
    And the structure in the zip for Ancient Greek Boats is correct -- the top-level folder named "Content" is just a placeholder for whatever your actual content folder is called, whether it's My Library, My DAZ 3D Library, Content, or whatever. If you install manually, you need to ignore the folder named "Content" and only install what's underneath that folder. That's what DIM does with those zips.
    I've been using the DIM since I upgraded my computer to Windows 7 Pro. Everything had to be reinstalled anyway, so I thought I'd give it a chance. That's the only installing that's been going on except for a few where I got that Install Failed! message and I was told to install them manually. Some of them I haven't bothered with yet, they're still in the Install tab in the DIM with the Install Failed! message.
    Dana
    Nice.
    What about things like pwToon and pwGhost and various other things that always seemed to need a new version when DS was updated! Anyone?
    Dana
    Dana
    ...yes I installed it via the DIM and all my plugins show "green".
    I do not have the full Dynamic Cloth Control plugin as I cannot afford it so I cannot advise on that.
    ...refresh the page. that should give you the correct grand total.
  • ps1borgps1borg Posts: 12,776
    Been overcast today but am a little sunburned from UV reflected off the water, looking like an under lit something from a horror B-Movie right now :lol:
    Rezca said:
    Shiiiny!
    Playing with caustics in Indigo :)
    Hey looks great, yay for white points ! :)
    Kyoto Kid said:
    Kadix said:
    Kyoto Kid said:
    One thing that bothers me is the main promo pic for the Amazing Skins or Belle 6 where she is in the Grecian Goddess skimpwear. Ummm....she's supposed to be a teenager, like under 18. She should at lest be in something more "modest" like a swimsuit or strap top and shorts.
    Hi, I just discover this post. This image was not at all intended to shock people, and I'm really sorry it bothers you. My intention was to show a poetic figure, actually a young goddess of nature, surrounded by fairies. The choice of the ouftit for her corresponded to the story of the scene (the bottom was morphed in Zbrush to cover the figure more).
    I have not thought it might bother someone because this was in my intention a kind of "Ode to innocence, nature, and poetry". In this situation, Belle was not really a figure any more, she became an "icon", the interest of using her, who is young, was to increase the feeling of innocence and purity to the overall scene. And not the contrary at all.
    When I saw the final render, I found it really poetic, and not provocative at all, but this is my personal feeling about it. Now reading you I realize the intention I put in the scene may not be interpreted the same way for everybody. So your feedback is good to take, I'll take more care to whenever I should render young people again and I'm sorry about that. But believe me my intention was the exact contrary of provocation.
    ...apologies for the misunderstanding, The story I am working on involves two of the main characters who, while they may be "adult" in age (according to UK standards in 2060 and even today) they have the appearance of young teens (12 - 13) There is more behind this of course but it would take far more space than offered here to explain and it would spoil a major part of the story to discuss here. I have to walk very fine line in how they are portrayed including manner of dress for though in most of the story they are "legal" adults not only in the UK but most of the NEEC (the European economic community in 2060) they would appear to be underage especially here in the US.
    Iz a difficult area for everyone to navigate :)
    TroutFace said:
    It's up to 56F here, but most of the country is buried in snow - at least in the Northeast and Midwest. :bug:
    Our weather is "warm enough", but "warm enough to have a beer on the bar patio" would be nicer! :coolsmile:
    *edit* Reality 4 looks interesting.. will probably get it even if my renders will take foreverrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr :blank:
    The snow is on our TV news, looking awesome and bleak all at once :)
  • SerpentSerpent Posts: 4,075
    Saturday morning! :)
    But, of course.. COMPLAINTS!
    - Woke up at 6:15AM, couldn't get back to sleep
    - Rain, rain, rain all weekend
    - Want eggs, too lazy to get wet getting brekky :long:
    - Looks like a 3 cup of coffee dreary day
    - Darn neck still hurts :down:
    Non-complaints!
    - Lots of super-tasty coffee :cheese:
    - Downloading new content while the coffee makes :coolsmile:
    - At 11AM, the Mexican place opens up and I can get huevos rancheros!!
    - Mexican place is one block away, so won't get too damp :)
    Renders in the not too distant future!
  • XyetztXyetzt Posts: 27,544
    Is it morning yet? Actually I know it is midnight and I am setting an apple while typing this. Been hungry since I started to try to sleep at ten. Hopefully the Apple will help me go to sleep. Otherwise I am going to stay up for the rest of the night.
    I guess I meant eating an apple not setting an apple. How does one set an apple?
    Maybe you can re-texture material zones on it? :-S
    It's wild to look at.. very otherworldy when it snowed here, could barey see 5 feet.. then everything covered in a blanket of glistening white crystals..
    But not so much fun to have to go out in! :ahhh:
    Time for more coffee...
    Slow render is slow. :smirk: Will post once it's done! :)
    Watching a render render whilst grinding coffee beans.. kind of Zen-like.. :coolsmile:
  • atticanneatticanne Posts: 3,009
    tjohn said:
    Kyoto Kid said:
    AtticAnne said:
    I'll have to look for flutterby lights. DD and I already have a few flutterby ornaments on our eclectic tree. A professional decorator told me many years ago that my tree was trashy and I should have a theme. My response: Each and every ornament has a special meaning to me and there is no way it will change other than adding more ornaments each year. So there! Surprisingly, he and I are still good friends.
    ...If a professional decorator came to my place, he or she would probably call both a Goodwill and Salvation Army truck in. and I'd wind up sitting and sleeping on the floor as I couldn't afford any of their redecorating/furnishing suggestions.
    Decorating Tip #14527:
    Bricks and planks stolen from construction sites make excellent shelves.
    I prefer cinder blocks. They don't topple over as easily as bricks.
    Forecast calls for large hail, 4-6 inches of rain, and high winds. I'm staying inside and watching my BP fluctuate wildly. Hit 197/110 at one point last night.
    Dang, that's nasty hail! :bug:
    But the BP thing is worse.. that's higher than my worst.. Take care of yourself! :red:
    Firehorse drop!! :coolsmile:
    612 x 792 - 56K
    He's probably right. :blank:
    Dana
    Dana
    He's got an attitude.. gets it from his human friend. :blank: :smirk:
    You'll see soon.. working on another render.. but slow render is slow.. :down: Using the Spot Render tool a lot lately as IPR on this machine... le sigh.. need a gaming laptop. :long:
    Experimenting with different settings on the coffee grinder.. I think I fund my fave, a kind of medium-fine grind.. :)
