I have an evil morph in my runtimes and i'm lost
If  you look at the attached picture you can see the problem i'm having with Genesis 8.1 Male's legs. I assume it's a problem with a morph i've installed but i'm having no luck in identifying which one,
Any advice, i'm so flustrated.
I'm tempted to delete all my G8M and G8.1M content and just start from scratch and only reinstalling stuff i use often - which would make loading a character much quicker - but i'm not sure how to do this without destroying G8F.
I don't want to spend all weekend on this...help!
  • barbultbarbult Posts: 27,618
    With your distorted character loaded:
    1. open the Parameters pane and enable Show Hidden Properties.
    2. Then with your character selected in the Scene pane, go back to the Parameters pane and click on Currently Used.
    3. Look through the list of used parameters on the right side of the parameters pane and look for suspicious pJCM or JCM parameters, like JCM files for a character that you don't even have dialed in to your character.
    4. Try zeroing it out suspicious parameters and see if that fixes the problem. If not, try zeroing other parameters until you identify the culprit.
    5. See if there is an update for the product that is causing the problem and install the update if there is one.
    6. If it is a Daz product, submit a help request about the problem.
  • MoogooMoogoo Posts: 136
    looks like an auto shape enhancer morph of the thigh, knee or calf, as barbuilt as said look in currently used and it will be there.
  • I think i solved it! when i deleted G8M orangatang the legs look okay. thank you Moogoo and barbult!
