Are there any convincing male body morphs for Genesis 8/8.1 Female?
Are there any convincing male body morphs for Genesis 8/8.1 Female? Professional, triple A quality preferably, not amatuer made?
I need Genesis 8/8.1 Female to have a male chest, but it has to look just like Genesis 8/8.1 male. It can't look amatuer. It has to be professional.
I need Genesis 8/8.1 female to have a chest that looks just like this:
Post edited by vozolgant on
https://www.daz3d.com/transgender-shapes-for-genesis-8
That's of very poor quality. I need something professionally made that looks identical to Genesis 8/8.1 male chest.
Those all look like female chests.
I hate to tell you, unless you make it yourself, that's as good as it gets, at this point.
That's what I was afraid of. It's gonna take me 2 days to sculpt it right in Zbrush, and to fix the normal maps. Damn it. I'd rather pay $30.00 to have it finished now instead of wasting 2 days.
Did you try this? It does work for G8.1 as well
https://www.daz3d.com/genesis-8-cross-figure-resource-kit
I just read that product's description.
How do I give Genesis 8.1 female a male chest using genesis-8-cross-figure-resource-kit ? This is not an issue of clothing, but morphing Genesis 8.1 female to have a male chest; which means its normal maps need to be adjusted as well.
https://www.daz3d.com/muscularity-morphs-for-genesis-8-female-s
But I don't know if you consider it having 'poor quality' or not
You may need to reduce the default G8F breast size first (iirc the morph should be included with the G8F figure)
(Oh and IMHO the quality of the transgender shapes was not poor at all)
I've already tried using morphs like that to flatten the chest. There's three things they don't do. 1) It doesn't adjust the curve of the chest, so even though it's flat, it doesn't take on the curvature of a male chest. 2) It doesn't correct the nipple positioning. 3) It doesn't adjust the normal map.
The picture on the left does not look like a male chest. The picture on the right is how a male chest looks.
Image removed
I tried a quick character with the cross figure and cross uv tools. I put some default clothes on since I didn't want a topless G8.1F (the top has some underwiring so you will see some concentric circles on the chest from the clothing).
In this case, why not try this
https://www.deviantart.com/agentunawares/art/Transgender-Genesis-8-723851486
You might need this to separate only part of the morphs
https://www.daz3d.com/shape-splitter
...Or just spin some head morph dials to make a G8M have a feminine face and slap a G8F texture on using
https://www.daz3d.com/genesis-8-uv-swap-male-and-female-base ...
I also have this: https://www.daz3d.com/genesis-8-cross-figure-resource-kit
Using that you get G8M's shape on G8F. Result below, wearing M8 skin.
I also managed to get M6's shape onto G8F using a combination of generation X and XTransfer. Image below, also with M8 skin:
I have been working the cross-gender stuff for awhile, but the other way. You can find all the recent information and step by step PDF instructions over at:
Auto Muscle Enhancer HD [Commercial] - Page 35 - Daz 3D Forums
Both the Transgender and Cross-Gender products work well. The Shape Splitter is essential to make separate head and body morphs. After that is complete you can transfer bodies and heads and mix shapes at will. TD
If you have any Genesis 8 Male or Genesis 8.1 Male Pro Bundle it comes with the "Genesis 8 Female Anatomical Elements for Genesis 8 Male/Genesis 8.1 Male. Then if you own that Michael 8.1 product you have a chest exactly like you were looking for.
Use MetaMixer, free for DAZ+ members, to make the face more feminine.
Well took this as a challenge, and an opportunity to play with the Shape Splitter | Daz 3D tool. Did what you asked on both the G8.1M and G8.1F figures.
For the G8.1F (Pink Belt) I split the https://www.deviantart.com/agentunawares/art/Transgender-Genesis-8-723851486 into a separate body only morph, also split the G8.1 Michael Chest morph from the rest of the Michael body, then transferred it to the G8.1F using the transfer utility tool. The rest of the transgender male body I used the Genesis 8 Female Body Morphs | Daz 3D to feminize the male looking figure. I used the Victoria 8.1 head and materials to finish off.
For the G8.1M (Blue Belt) I used the same Michael 8.1 Chest only morph that was created with the Shape Splitter tool, then split the transgender head into a separate morph. I transferred the Victoria 8.1 head using the transfer utility tool, and then used the same Victoria 8.1 Materials by using the https://www.daz3d.com/uv-swap-for-genesis-81. I carefully matched all the settings between Genesis 8 Male Body Morphs | Daz 3D and the G8.1F so they are basically duplicates
That is your requested Michael G8.1M chest on both figures! For pictures and instructions on using the Transfer Utility Tool you can go to my post at the bottom of P. 28 at: Auto Muscle Enhancer HD [Commercial] - Page 28 - Daz 3D Forums.
Creating and saving custom morphs on P. 35 at the same forum.
Good luck, let us know if you get what you required. TD
It depends on the G8 Female character you start with?
I got his https://www.deviantart.com/alien-area/art/Frej-8-1-879043728 on my deviantart page (full nudity).
alienarea,
Short answer, yes. If you want to keep the transferred Morph accurate though, you would need to "Layer" it over the transgender or cross-gender baseline morph. Putting another figure or shape in the mix will change the outcome. Could lead to some interesting results though. My attempt here was just to demonstrate on the baseline G8.1 Male and Female shapes to get the requested results.Hope that helps. TD
