DS3A inject plugin help?
Guardian Angel 671Guardian Angel 671 Posts: 234
I was wondering how to get this to work now? I use Win 7 64 bit & have the 64 bit version of DS3A installed. I used this version of INJECT PMD PLUGIN FOR DAZ -- http://www.4shared.com/file/V-WdDpdO/InjectPmd_x64.html . Is it the wrong one?Also how do I know if I have the correct 1 & if it's working?
Thanks,
Rose
  • SlimerJSpudSlimerJSpud Posts: 1,456
    You might want to look at this thread:
    http://www.daz3d.com/forums/discussion/47169/
    I have this plugin. I can check back later when I'm at the Daz computer. Is it an install issue, or a running it issue? What PMD are you trying to inject?
  • Guardian Angel 671Guardian Angel 671 Posts: 234
    interesting thread & i may try some of that out. I ended up trying this version of the plugin http://www.4shared.com/zip/jdphln3k/injectpmd_3018_win64.html . It shows up & tries to load but I get an error message saying:
    File error:Directory length mismatch. Expecting 0x530,got 0x202
    But no idea what that means. The previous version was installed into DS3's plugin folder but said it failed to load,so I'd say a running issue? I was trying to inject pmd morphs of an item that I'm testing into a figure but I guess not lol.
    Hmm. It works for me. I have the free Felicity hair and some morphs that won't load just by double clicking on the pz2 file. I go to Edit > Inject PMD, and then navigate to the same pz2 file and it works. How are you trying to run it? The dll does go in the plugins directory where Daz Studio is installed. You might want to check the pz2 file in a text editor to see if the path to the actual pmd file is correct. Normally, the pz2 file calls the pmd file by name, and if it's in the same directory, it works. If there is a long path in the pz2 file, like "C:\Documents and..." then the pz2 is broken.
    Now that I've tried this, there are several other morphs that I need to try again. LOL
