Save and reuse a pose.
Translated with Google
Hello, I tried to use save as / pose present and then import to save and reuse a pose, as you already know it doesn't work.
What is the exact procedure?
File > Save As > Pose Preset
You save your file in your library, into a folder where you have yours poses
Then you make a refresh for your library.
Now, you can see the thumbnail in the directory where you put your pose.
You select the body and you click on the thumbnail.
Select the figure, then use File -> Merge, and load the Duf file containing the pose preset. You can do that in lieu of creating a folder in the content library.
Thank you all !
