Save and reuse a pose.
Translated with Google
Hello, I tried to use save as / pose present and then import to save and reuse a pose, as you already know it doesn't work.
What is the exact procedure?
  • Willy2Willy2 Posts: 182
    File > Save As > Pose Preset
    You save your file in your library, into a folder where you have yours poses
    Then you make a refresh for your library.
    Now, you can see the thumbnail in the directory where you put your pose.
    You select the body and you click on the thumbnail.
  • margravemargrave Posts: 1,822
    Select the figure, then use File -> Merge, and load the Duf file containing the pose preset. You can do that in lieu of creating a folder in the content library.
  • Thank you all !
