Advice for underwater ruins or underwater swamp?
I'm kind of picturing something like swimming portions of the early Tomb Raider games, what are some products that would be good for creating underwater ruins and swamps?
And just to be exact, when I say underwater, I mean it would look good from an underwater POV.
Post edited by Diaspora on
The Albert Mansion Sunken Add-On might be useful to you (requires Albert Mansion, although I suspect you could get some use out of it even without that).
For lighting, I've had some decent results from the Laguna Underwater Lights. For ruins, you might want to take a look at Stonemason's Gothic Ruins. And you'll probably want some Seagrass.
Thank you for all the leads, and yeah, I already own the albert mansion stuff!
Anything that looks weathered can do. I used Pharaoh's Ruin for the Shark Tail Texture add-on Promos, for example:
These could work as well:
I bought Albert Mansion Sunken Add-on (https://www.daz3d.com/albert-mansion-sunken-add-on) today (actually, a freebie today). When I select Camera 04 Underwater, the opacity of the pond is far too thick and nowhere close to the promo image from the camera; see screen capture 1. The default opacity of the pond is 1.00 and the opacity is very thick; see screen capture 2. If I decrease the opacity of the pond by the smallest amount to 0.99, the opacity almost becomes that of clear air; see screen capture 3.
Does anyone who has the set have any suggestions on how to get an underwater opacity like in the promo image? Thanks in advance.
