I'm Sorry, Filament. I guess you really do Rock!!!
2»
  • DartanbeckDartanbeck Posts: 21,988
    WendyLuvsCatz said:
    3Delight does a lot of things even iray cannot do
    but also sadly too slowly for animation
    I haven't played with 3Delight yet since I just started getting into DS, mainly because I love the Iray results so much.
  • SpaciousSpacious Posts: 481
    As far as I can tell Filament is some sort of offshout from OpenGL, that runs the texture shaded preview.  It seems like it has all of the same inconsistencies with regard to Transparency.  I seriously doubt this will change because it's built into the core of how it works.
  • PadonePadone Posts: 4,073
    edited November 2021
    Dartanbeck said:
    For hair and other seemingly problematic surfaces, I noticed a Huge improvement to everything when I open the Drawing pane under "Drawing" and turn off Avatar drawing.
    Just turned off "draw avatars" in the draw settings and didn't notice any improvement here. The transparency bug is not fixed and hairs seem the same as before. May you post some pictures of  the "huge improvement" you get please ?
    Post edited by Padone on
