i13 Theatre Lighting
Geminii23
in The Commons
Hi. Does anyone know an easy way to change this into a day time scene? I've tried adding distant lights and also changed rending to Sun-Sky Only with time of day. Scene always renders as nighttime.
Here is a quick render of the theatre I removed all outside lights, turned off all outside emissives and used Sun-Sky Only with finite sphere.. It came out reasonably well, and if you save it as a scene subset it will save you the hassle when you need it again..
Thank you thank you! It was the finite sphere that was giving me trouble I think. Now the time of day setting in Sun-Sky is working.
