i13 Theatre Lighting
Hi.  Does anyone know an easy way to change this into a day time scene?  I've tried adding distant lights and also changed rending to Sun-Sky Only with time of day.  Scene always renders as nighttime.
  • CHWTCHWT Posts: 1,191
    Did you hide those parts which are not in your camera? Or just load those parts you need in your scene?
  • Ghosty12Ghosty12 Posts: 2,093
    edited November 2021
    Here is a quick render of the theatre I removed all outside lights, turned off all outside emissives and used Sun-Sky Only with finite sphere.. It came out reasonably well, and if you save it as a scene subset it will save you the hassle when you need it again..
    1000 x 600 - 431K
    Post edited by Ghosty12 on
  • Geminii23Geminii23 Posts: 1,328
    Thank you thank you!  It was the finite sphere that was giving me trouble I think.  Now the time of day setting in Sun-Sky is working.
