Polygon Group Editor Basics
alexhcowleyalexhcowley Posts: 2,404
Guys,
I've been trying out the Polygon Group Editor this morning and I've hit a problem. I've selected the editor and the surface, a yellow line has appeared around it.
I can't get the polygon selection menu to appear. When I right click on the surface, all I get is a surfaces menu. I have attached a jpeg which shows the screen.
I suspect I am making a very basic, noobies mistake. I have searched the forum but I can't find any noobie-proof answers to this problem.
Many thanks for your attention.
Cheers,
Alex.
    That is the Surface Selection tool that you have selected, you want the one three to the right, Geometry Editor Tool (Alt+Shift+G)
  • BejaymacBejaymac Posts: 1,958
    You also need to have the Tool Settings tab open as that is where the interface for it is located.
  • alexhcowleyalexhcowley Posts: 2,404
    Jimmy,
    Thanks for your fast reply. I was following these instructions:
    Tools
    Select Item in scene
    Polygon selection
    The instructions should be:
    Select item and surface first.
    Invoke the Polygon Group Editor
    Right click on the selected surface to invoke the Polygon selection menu
    Another, related, thing I found out the hard way: Once the gown has been edited and a new surface has been created, highlight the genesis figure in the scene pane and then save the gown as a wearables preset. Exit Daz, re-enter and then apply the saved preset to the figure.
    Cheers,
    Alex.
