Polygon Group Editor Basics
alexhcowley
Guys,
I've been trying out the Polygon Group Editor this morning and I've hit a problem. I've selected the editor and the surface, a yellow line has appeared around it.
I can't get the polygon selection menu to appear. When I right click on the surface, all I get is a surfaces menu. I have attached a jpeg which shows the screen.
I suspect I am making a very basic, noobies mistake. I have searched the forum but I can't find any noobie-proof answers to this problem.
Many thanks for your attention.
Cheers,
Alex.
1920 x 1200 - 458K
That is the Surface Selection tool that you have selected, you want the one three to the right, Geometry Editor Tool (Alt+Shift+G)
You also need to have the Tool Settings tab open as that is where the interface for it is located.
Jimmy,
Thanks for your fast reply. I was following these instructions:
Tools
Select Item in scene
Polygon selection
The instructions should be:
Select item and surface first.
Invoke the Polygon Group Editor
Right click on the selected surface to invoke the Polygon selection menu
Another, related, thing I found out the hard way: Once the gown has been edited and a new surface has been created, highlight the genesis figure in the scene pane and then save the gown as a wearables preset. Exit Daz, re-enter and then apply the saved preset to the figure.
Cheers,
Alex.
