Having trouble recoloring a clothing
The original color was red and gold. I wanted it to be white and purple. I only changed the base color map. How can I get the sides to be entirely purple, and fix the shade of gold on the collar? In the view port the side is entirely purple but not in the render.
  • Please don't post texture files (other than any you create yourself, but I believe this was just a modification of the existing map).
    Most likely that is not controlled by the base colour but by another property in the Surfaces pane - one of the glossy or top coat values, perhaps, if it is using the Iray Uber Base shader.
  • If all else fails, select all the surfaces and apply one of the basic Iray shader presets, then adjust the colours and reapply the desired texture images.
