Having trouble recoloring a clothing
The original color was red and gold. I wanted it to be white and purple. I only changed the base color map. How can I get the sides to be entirely purple, and fix the shade of gold on the collar? In the view port the side is entirely purple but not in the render.
1218 x 1032 - 314K
Please don't post texture files (other than any you create yourself, but I believe this was just a modification of the existing map).
Most likely that is not controlled by the base colour but by another property in the Surfaces pane - one of the glossy or top coat values, perhaps, if it is using the Iray Uber Base shader.
If all else fails, select all the surfaces and apply one of the basic Iray shader presets, then adjust the colours and reapply the desired texture images.
