Restricted Hallway Questions
MJ007
Hello all,
I have a few questions regarding the setup of the Restricted Hallway:
1.) Is this a simple straight hallway? No corners or turns in it?
2.) Are the elevators at the opposite ends of the hallway?
3.) The description states there are 2 poseable doors... where are they?
4.) Can someone render a complete overhead shot of the hallway?
-MJ
Post edited by MJ007 on
Just a single straight hallway, although there are sticky-out bits just deep enough for your characters to hide in (if you dial "should eat more" high enough).
One elevator at the far end, the scene's zero point is at an open end.
Two doors, halfway along each long wall.
Can't do a render just now, I'm in the middle of test-rendering something else. Think of a grungy-tech concrete and steel version of A Curious Hallway.
Overhead view with the Ceilings 1 - 5 turned off (basic render, no lights), and with the two doors opened.
Also, the elevator doors open and close too.
From the promo photos (attached below) and the description ("2 Pose-able elevator doors"), it appears there are two different elevators. Is this a misprint? If not, and one end is open and the other end has an elevator, where is the 2nd elevator?
-MJ
It says there are two posable elevator doors, NOT two elevators.
The second promo shot, is inside the elevator looking out.
It also says '1 Pose-able elevator' which may not have been there in the beginning, I don't know.
the "2 Poseable elevator doors" refer to the fact that there are 2 doors on the elevator itself, the left and right one, which open and close.
It took me a while to work it out, but the second pic, is a shot taken from INSIDE the elevator, looking out into the hallway. The girl is IN the elevator, the monsters are outside in the hallway, with the two doors partly open:D
Btw, the elevator itself also goes up and down.
edit: JimmyC was quicker off the mark than I was.:D
Ok, got it. Thanks everyone!
-MJ
