Need Help with Product IDs
Nyghtfall3D
Since there's no way to contact vendors themselves, and the new store layout has made it even more difficult to find what I want, I'm posting here.
Does anyone know where I'll find the peep-toe pumps used in the first and sixth promo renders for this 70's wrap dress:
http://www.daz3d.com/that-70-s-look-70-s-wrap-dress
I'm also looking for the pumps used in the first promo render for Miss Fisher's Wardrobe 2PC Dress:
http://www.daz3d.com/miss-fisher-s-wardrobe-fantastic-2pc-dress
And the pumps used in the first promo render for Miss Fisher's "Feminine Wiles":
http://www.daz3d.com/miss-fishers-wardrobe-feminine-wiles
Thank you.
Likely these
http://www.daz3d.com/open-toed-pumps-for-genesis
Nope, those have a platform. None of the links I posted feature platform shoes.
what about these for Gen2F?
http://www.daz3d.com/open-toe-pumps-2-for-genesis-2-female-s
no platform, and have the open toe.
Those look nothing like the shoes in the promos I linked to, and couldn't have been used in the promos anyway, because they're a new product.
I'm looking specifically for the shoes used in the links I posted.
Then do a search for Aave Nainen on the forums and see if she has done commercial posts, and send her a PM. I just did and found her.
Thanks for the tip. I just PM'ed her.
In case anyone else is looking for these shoes:
http://www.daz3d.com/gracepumps
They transfer to G2F very well although IIRC I had to add a smoothing modifier :)
Excellent. Thank you, Aave.
To apply a smoothing modifier, load the shoes onto the figure and apply the foot pose to figure that comes with the shoes. Select the shoes in the SCENE tab and then go to the little arrow icon near the top, in the popout window go Edit _Apply Smoothing Modifier. It will by default apply a Base Shape Matching smoothing modifier of 2 which you can change in the Parameters pane.
Just bought the Grace Pumps and am testing them with G2F. This is what I get after telling DS they were designed for Genesis Feet and applying the Foot Set pose that comes with the shoes. What'd I do wrong?
Did you apply the foot pose before loading the shoes? You have to load them with G2F in default pose......then apply the foot pose......they will look ridiculous at first but should be okay after auto transfer finishes and then you apply the foot pose.
Hmmmm.........I just tried it to be sure I wasn't leading you down the wrong path........that procedure no longer works it seems. I'll try exporting the shoes as obj and bring them back in.
Just tried that, and got the same result.
Try using this tutorial from Sickle Yield
http://www.deviantart.com/browse/all/?qh=§ion;=&global=1&q=fitting+shoes+to+G2F
I just spent the last several minutes trying to get the shoes to work, using that tutorial. It's not worth the headache I'm getting.
I'll just use them with Genesis...
Thanks anyway...
Lol......I just did the same thing and can't get it to work.........odd.......I used those shoes on the 70's Wrap Dress for G2F Promos and that was not very long ago, I must have just been lucky that day. Sorry I couldn't be of more help.
