Problem with rakshasi product
when i apply the rakshasi body the thumbs bend strange and weird way. is it just me happen or is it known issue? if that so is there way to fix this??
Apply all the other Rakshahi morphs first, and then see if there's still a problem.
Yeap i try that too and that's the only one making the problem. the body morph
Please submit a ticket if no solution is forthcoming here.
Probably a conflict with another asset..
Check to see if any other morphs are being activated when you do that, in the "Currently used" section
If there's nothing else there, dial down to the thumb node and check the contollers for the bend channel. click the gear icon on the slider the the controllers tab.
It might take a bit to figure out what you're looking at and what might be causing the conflict, so try to have a bit of patience.
