Adding to Cart…
Oh don't worry about it, I didn't know it wasn't normally part of your workflow. Thanks, you've really been quite helpful.
I'm aware...further proves my point that maps can't replace true HD topology in all cases.
Displacement will move the geometry, and like HD morphs it works on the vertices created by SubD. However, in the available shaders it works only along the normal direction (in/out, no side-to-side): in principle it should be possible to implement a vector displacement shader that could read colour RGB values as x, y, z for displacement.
I don't see how even a displacement map could create something like two spines that protrude from the chin and then twist around each other, coming to a point.
An HD morph would have problems too - both are limited by the available mesh density, and increasing that affects the whole model so it isn't possible to add local additional density. For the sort of thing you describe a geoGraft would be the more practical solution.
