Adding to Cart…
Those are GREAT Richard... Thanks for sharing. Just goes to show...One never knows where one will get inspiration ;)
I have to add my thanks for WilmaP's great freebies, they are usually my go-to's for all kinds of renders. I mostly just render quick Genesis 1 poses for comic reference, can usually find the clothes I want.
Glad you know you're still around Wilmap and can fully understand not being able to keep making 3D content. Love your stuff and still use it.
Great textures LlolaLane and RicharNTracey
I like this idea! Here's one more:
Gallery link
To dForce the kilt you'll have to deactivate the entire bum area via weight map, or DAZ Studio will crash.
Or at least that's what happened to me :)
Oh my (fans self)... hubba hubba... Too bad he smokes :( ... lol.
Thanks for the heads up on the dForcing ;)
Hey. I would like to ask for an assistance with one of the products from this free site. This one: https://www.wilmapsdigitalcreations.co.uk/view_product.php?id=172 for some reason dress materials does not work for me (the ones for bow work perfectly) no mater which material i click the dress stays default white.
You may have to manually put them on the dress.. I'm not sure Wilmap is still around or supporting her stuff. These are really old.
The included materials don't show in the preview window ,you pick the dress in the scene tab click on the material you want ,when you render the material shows up or you can just select the dress in both the scene tab and the surface tab then apply a shader.
Ah... you need "3Delight" settings .. NOT... Iray to see them. Important bit of needed information. Took me a while to figure this out... Make sure you add some lighting to your 3Delight settings or the character will be black!
Please also note... Iray textures look lovely on the dress... and I even converted it over to Dforce and it looks quite nicely draped! (first is 3Delight.. second is Iray)
Llola ,yup I use 3 Delight But the materials still don't show in the viewport preview ,and the surface settings are different from 3 DL or iRay .......
Yeah.. it's a shame 3Delight doesn't have a preview like Iray... I had to just render it also to see it. Weird the textures don't show up... Must be the way they were saved.
Anyway... hope this helps ancanar_3dfb1cf89d
There is the Aux Viewport - that was what it was added for, really.
Would it be possible for You to share the iRay versions of mats? Or tell me how to convert them by myself?
Thanks.. I had not tried the Aux Viewport since I don't use 3Delight much anymore... ;)
Super simple ancanar_3dfb1cf89d ... if you have any of these 'shaders' https://www.daz3d.com/catalogsearch/result?q=iray+shaders you can apply them to the dress... just click the dress and apply the shaders. I'm sure you have some in your library... just make sure you set it to RENDER with Iray.
hum.. you got me thinking... Halloween and Christmas gift time is coming along... Maybe I'll make some Iray shaders for the dress of my own textures. If I do... I'll message you. Depends on how busy I get... Darn the days are going faster as I get older... Ughhhh
I have had this item "forever" and I do appreciate the artist and the work that went into it.
I do have to add one issue from a kilt wearer, and these two items are minor:
1. For a man OR a woman, the kilt does not lay over the front right to left but left to right. For example, when you look at the kilt pin, it is supposed to be on the "Open side" to help add weight to the kilt (it is NEVER pinned closed). Now, when I look at the product, the pin is on the lower left. And I can see the kilt "front flap" is on from right to left. The rule is always pleated to the rear with, the flat flap (or Apron) to the front from the left. https://clan.com/help/kilt-tailoring-finishes/kilt-construction-anatomy
2. The sash is placed over the right shoulder. Only chiefs of the clan are allowed to wear the sash over the left shoulder (or pipers are allowed to). It should be over the left shoulder for all Clansmen. The sash for a Lady is the same "rule": only the Clan Chief or their spouse wears it over the right shoulder.
Also a great kilt (Belted Plaid (breacan an fhéilidh) or great plaid (feileadh mòr)) for Men would be a great addition to the outfits of Scottish highland members!
Thanks. I use your freebies and appreciate your work.
Thank you Wilmap, for the clothes you created, they are very beautiful and I still use them a lot.:)
Can anybody else login to Wilmap's site right now? Looks like a Captcha glitch.
Yes.. I can get in... Here's where I'm linking to...https://www.wilmapsdigitalcreations.co.uk/introduction.php
hum.. I guess I can't.. no matter HOW many Captchas I do :( I guess the site is broken!
Hoping she's alright.
I also can't register because of
Hope it is only a temporary reCaptcha problem.
I also couldn't log in and it's the first time it's happened. I hope they restore everything soon and above all that she's fine.
I can access the site with Firefox, but I have already logged in, and it saves the login credentials and site cookies. I tried logging in Chrome and Brave, where my credentials aren't saved, and it works . However, it doesn't work in an incognito window in Chrome
I can see the site but when I go to download something it says I need to login... Have you tried downloading something WandW ???
Downloading with Chrome on a PC is fine for me, as is logging in.
Regards,
Richard
ok.. I got into site and was able to download something... Seems I had 2 Wilmap passwords... Not sure how that happened... lol. You all may want to check your password settings.. That's how I found out :) Good luck.
Stay well everyone. Hugzzzzzzzzzzz
