Hiro3 Alien
MJ007MJ007 Posts: 1,717
Hello,
I need to create an alien character using Hiro3 (not Genesis Hiro3).
Is anyone aware of inexpensive packages to accomplish this? The more alien-looking the better. Preferably, I would like a package in which i could make a young and old version of the same alien species.
Thanks in advance!
-MJ
    MJ007 said:
    Hello,
    Thanks in advance!
    -MJ
    What type of alien? A Grey? CP used to carry the old Grey Alien bundle. RDNA also has a Greyling. Both these are stand alone figures that can be used in any version of Poser or DS.
    Sixus1 has an updated Grey with an expansion pack (it has ages and other morphs). This is a stand alone figure for P9 and up. Only other set of morphs to check is Capces Digital Ink's morphs for H3. Did you check the H3 cr2? H3 is the only Gen 3 figure that came with all the morphs.
  • HavosHavos Posts: 5,687
    edited November 2014
    This morph pack for H3 contains a couple of Alien morphs
    http://www.daz3d.com/hitoro
    Post edited by Havos on
    This pack is for Aiko 3 - http://www.daz3d.com/mylilalien
    The morphs may be able to be used. Being a Generation 3 character the mats will work with Hiro 3 just fine.
  • ModernWizardModernWizard Posts: 904
    If you're at all familiar with magnets [Poser] or D-Forms [Daz Studio], mapps has a set of free magnet presets for creating head morphs for Aiko 3. http://www.renderosity.com/mod/freestuff/?item_id=30156 With a little repositioning, they could easily be used on Hiro 3 as well.
    --MW
    EDIT: And Kattey has a wonderful freebie set of Critter Morphs for both A3 and H3: http://www.renderosity.com/mod/freestuff/?item_id=39832 .
    Post edited by ModernWizard on
  • MJ007MJ007 Posts: 1,717
    To clarify,
    [icprncss]
    I am not looking for any particular "type" of alien... just need to make an alien character however using H3 as a base of that alien character is a must.
    [Havos]
    I checked Hitoro previously, and I couldnt find anything I liked or felt was "extreme", i.e. "alien" enough.
    [Mattymanx]
    MyLilAlien is also not extreme/alien enough.
    [ModernWizard]
    Those critter morphs might do the trick. I will have to download them and check them out.
    -MJ
  • robkelkrobkelk Posts: 3,259
    Checks the freebie list...
    Klingons probably aren't alien enough.
    http://www.sharecg.com/v/22010
    Critters might or might not be alien enough - I think these are Kattey's, just at a different download site.
    http://www.sharecg.com/v/21572
    Ah, here we are... Reptiloids!
    http://www.sharecg.com/v/38122
    Now if ShareCG would stop acting up so folks could actually get at those morphs...
    Post edited by robkelk on
