Hiro3 Alien
MJ007
Hello,
I need to create an alien character using Hiro3 (not Genesis Hiro3).
Is anyone aware of inexpensive packages to accomplish this? The more alien-looking the better. Preferably, I would like a package in which i could make a young and old version of the same alien species.
Thanks in advance!
-MJ
What type of alien? A Grey? CP used to carry the old Grey Alien bundle. RDNA also has a Greyling. Both these are stand alone figures that can be used in any version of Poser or DS.
Sixus1 has an updated Grey with an expansion pack (it has ages and other morphs). This is a stand alone figure for P9 and up. Only other set of morphs to check is Capces Digital Ink's morphs for H3. Did you check the H3 cr2? H3 is the only Gen 3 figure that came with all the morphs.
This morph pack for H3 contains a couple of Alien morphs
http://www.daz3d.com/hitoro
This pack is for Aiko 3 - http://www.daz3d.com/mylilalien
The morphs may be able to be used. Being a Generation 3 character the mats will work with Hiro 3 just fine.
If you're at all familiar with magnets [Poser] or D-Forms [Daz Studio], mapps has a set of free magnet presets for creating head morphs for Aiko 3. http://www.renderosity.com/mod/freestuff/?item_id=30156 With a little repositioning, they could easily be used on Hiro 3 as well.
--MW
EDIT: And Kattey has a wonderful freebie set of Critter Morphs for both A3 and H3: http://www.renderosity.com/mod/freestuff/?item_id=39832 .
To clarify,
[icprncss]
I am not looking for any particular "type" of alien... just need to make an alien character however using H3 as a base of that alien character is a must.
[Havos]
I checked Hitoro previously, and I couldnt find anything I liked or felt was "extreme", i.e. "alien" enough.
[Mattymanx]
MyLilAlien is also not extreme/alien enough.
[ModernWizard]
Those critter morphs might do the trick. I will have to download them and check them out.
-MJ
Checks the freebie list...
Klingons probably aren't alien enough.
http://www.sharecg.com/v/22010
Critters might or might not be alien enough - I think these are Kattey's, just at a different download site.
http://www.sharecg.com/v/21572
Ah, here we are... Reptiloids!
http://www.sharecg.com/v/38122
Now if ShareCG would stop acting up so folks could actually get at those morphs...
