daz Render Engine Problem.
I receive this banner every time I try to render Iray in DAZ Studio 4.15.
I have no idea what the problem is. All was going well till an hour ago. I have also uninstalled DAZ Studio and reinstalled it. Cheers
...did you quit a render while it was still loading to the GPU (Iray) or optimising the scene (3DL)? That is usually when I've seen it.occur
Which render engine is it (Iray is the default)? What Drawstyle is the Viewport using?
I'vce had this happen several times. Aklways ended up having to kill Daz in Task manager, even if the program appears top be closed it still lingers there.
I have run into this error message with Iray render after disabling 3dlight render in the plugin setting. Might not be what causes it for you, but just one possible reason.
I've had this happen whenever a render crashes. There's no way to clear it without killing the process in Task Manager. I've reported this problem to Daz but never received a solution. I take it to mean they don't know.
