• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic dforce Soft Curls Base not rendering
tam_c3df5332fctam_c3df5332fc Posts: 122
October 2021 edited October 2021 in Blender Discussion
Hey guys,
I have had this issue with both the Daz to Blender bridge, as well as, with Diffeomorphic, which is that I cannot render dforce Soft Curls Base - https://www.daz3d.com/dforce-soft-curls-for-genesis-8-and-genesis-3-females
You can see the hair is on the model within Blender, but then when I render, then it renders a bald model - see attached screenshots.
I do not have this issue with any other hair objects. Is there a setting that I have to change when using dforce Soft Curls Base?
Post edited by tam_c3df5332fc on October 2021
  • jeff_someonejeff_someone Posts: 254
    October 2021
    What about in Material Preview/LookDev view mode?
  • tam_c3df5332fctam_c3df5332fc Posts: 122
    October 2021
    Thank you for responding @jeff_someone,
    The hair appears in material preview mode as well - see attached screenshot
    For some reason, it is not rendering
    1897 x 1040 - 935K
  • PadonePadone Posts: 4,001
    dforce hair has to be converted to particles, then I'm not sure why the material preview shows polylines
    https://diffeomorphic.blogspot.com/p/hair-section-version-16.html
    Post edited by Padone on October 2021
  • Krys KryngleKrys Kryngle Posts: 311
    October 2021
    The description says it's strand based hair.  Check out the link Padone provided.  There is a section on importing SBH.  I've never done it so I cannot help.  Let us know how you make out.
    When you mentioned importing, that lead me to export the hair from Daz as an obj file, from there I added the same textures used within Daz - scebony13.jpg, but the same result occurred, in that, it rendered as a bald character.
    As a result, I used an old Poser texture. It still does not render. I am at a loss. I have been rendering obj files since 1994 using Sketch by Alias Wavefront and I have never encountered something like this.
    When I open the obj in Strata, it does not appear to exist - see screenshot
    I tried to search for an obj file with the name soft or curl, but this is coming directly from a .duf file, so I opened the "dforce soft curls.duf" file directly and exported as fbx this time, with embedded textures checked - once again, nothing - WTF
    What is so perplexing about all of this, is that, this is the perfect hair for this character.
    I have even tried to export the hair from blender as an obj file, but when I open it in strata, once again - nothing - as if it does not exist or something.
    If I could have seen the object, then I would have converted it to a polygon mesh, followed exporting it again as an obj file to import into blender
    1351 x 918 - 420K
    1888 x 1067 - 480K
    1879 x 1061 - 530K
    1018 x 828 - 207K
    OK, I did another google search and the answer was already in the forums for another dforce hair product.
    Thanks to @Siciliano1969
    When you go to the Parameters tab/All and activate Preview PR Hairs and increase the Viewport Line Tessellation Sides and Render Line Tessellation Sides the hair appears
    I set Viewport Line Tesselation Sides to "2" and Render Line Tessellation to "3"
    Keep in mind that I thought my Daz studio was frozen while it completed this process. I did a spot render, which made me think this was going to work - see attached screen shot
    Further more, when I went to export via Diffeomorphic, it took ten times the usual time to complete, again making me think that my Daz studio had frozen.
    Same for actually importing within Blender. I literally started the process and went for a walk while it completed.
    Rendered the same result - bald character. I then exported the hair once more, because I could tell there was a difference in the look of the hair. It no longer had that muddy look and I was correct. The object now shows in Strata - see screenshot
    As a result, I exported that file as an obj file, followed by importing it into Blender. BTW, I had to change the size by 0.0001 for x, y and z for it to appear correctly - see screenshot
    Went into Shading and added the old Poser hair texture file, followed by rendering and this time, it looks like there is hair ghost - this is ridiculious
    I do not know what else to try, other than to give up on this particular dforce rendering via Diffeomorphic to Blender and try another hair.
    Ironically, out of all the products of hair that I have purchased or downloaded, this is by far my favorite and I have never been able to have a successful render of it in Blender
    1776 x 1074 - 517K
    1891 x 1052 - 1M
    873 x 714 - 168K
    1867 x 1053 - 748K
    1898 x 1050 - 506K
    1770 x 882 - 454K
    1490 x 975 - 997K
    @tam You don't need to tesselate the viewport in this case, dforce hair are exported as polyline. Tessellation is only needed for sbh, that's not your case. If your hair is sbh then you get a sbh node in the scene, so you can tell easily if it is dforce or sbh. Again please follow the docs.
    I agree it is not trivial to use the hair conversion tool, and some time ago I asked to Thomas if some "automation" would be possible so that the tool could recognize by itself the various hair types. But it seems this is hard to do. On the other side the tool is very flexible this way once you learn to use it.
    steps:
    1. export your hair, no need to tessellate since it's dforce, it will be exported as polyline
    2. import in blender and convert polyline to particles with the "make hair" tool
    3. you may have to adjust the strand steps and children in the particle hair depending on your needs and preferences
    611 x 337 - 46K
    October 2021
    @tam Other than diffeomorphic there's also the hair converter by @Cinus though I understand it is more limited in the types of hair it can handle.
    https://www.daz3d.com/forums/discussion/445851/hair-converter-add-on-for-blender/p1
    Thanks for the replies @Padone
    What should I export the hair as an obj, fbx, etc...
    In the link that you gave, what kind of hair is this considered to be? Sheet Hair?
    Is there a tutorial that gives a step by step?
    Also, it looks like they load the hair by itself, without the model - is this correct?
    October 2021
    I am trying your suggestions with another dforce hair that I have purchased.
    In trying to follow the steps of exporting with diffeomorphic and importing, followed by clicking on the "Make Hair" button, it seems like it has changed the hair to look more like strand based hair
    In the end, it worked - see screenshot
    Now, the hair does not look like I want it to look like, but I am at least seeing the hair in the render
    Thank you @Padone
    423 x 857 - 335K
    @tam Yes dforce hair are to be converted to particles in blender. You can adjust the look in the particles panel. Specifically the strand steps, children and children radius will affect the curve and density of the hair, while the root and tip radius will affect the look of the single strand. The make hair tool groups together the relevant parameters.
    https://docs.blender.org/manual/en/latest/physics/particles/index.html
    218 x 226 - 14K
    June 2022 edited June 2022
    Padone
    I am trying to do the same thing in Blender 2.93, but I cannot find the "Make hair" tool. Has it moved or does it need to be installed as an Addon?
    Thanks in advance
    Post edited by tam_c3df5332fc on June 2022
    Version 1.6.2.1039 works fine here with blender 2.93. What's your plugin version ?
    The make hair tool is in advanced setup > hair.
    Post edited by Padone on June 2022
    June 2022
    Thank you Padone
    I unchecked "Multi Materials" and "Keep Material" to make it match the screenshot that you have above
    June 2022
    Hey @Padone
    The scalp is not rendering or is transparent. Do you have any ideas on how to fix that? see attached screenshot
    1158 x 736 - 992K
    June 2022
    Is it a transmapped or dforce hair ? How does the scalp look in iray ? Can you link the product page ?
    June 2022
    @Padone,
    I think it was the following, but I am not sure because I did the Daz file maybe sometime in August of last year.
    It looks great in iray - see attached screenshot - if Daz rendered in Cycles, then I would not bother with Blender
    3840 x 2160 - 6M
    June 2022
    Hey @Padone,
    I was able to go into the original Daz file and add a Toluise hair, but it does not look great - at least the character does not look like she is balding.
    Unless you or someone else can come up with a work around, then this is what I will animate the remaining ninety frames - see attached screenshot
    3840 x 2160 - 1M
    Below it's what I get with the soft curls. It's a straight import and looks much better than yours. Perhaps you used sparsity to reduce the strands ?
    Also the hair cap looks exactly as daz studio.
    I used cycles with the bsdf option for materials that's required to mimic iray. The principled option is for eevee and it's expected that you may need to fix something, because eevee and the principled shader can't reproduce all the iray features.
    blender 3.2.0, diffeo 1.6.2.1041
    edit. note. Added a report for Thomas about multiple materials for dforce hair. Also the resize option seems to take a very long time here so I go without resize.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/1050/multiple-materials-for-dforce-hair
    817 x 518 - 80K
    June 2022
    Thanks for getting back to me @Padone
    Sorry, that I have taken so long to reply.
    OK, so I installed diffeomorphic 1.6 (Daz and Blender), along with Blender 3.2
    I did a "Import Daz" rather than my usual "Easy Import Daz" - is that what you mean by "It's a straight import"
    When I try to "Make Hair" - the button is greyed out - see screenshot 1
    When I look under "Shading" there is a  Hiar BDSF and Diffuse BDSF - see two screenshots
    Are you saying that I have to change one of those to Principle BDSF?
    I do see the skull cap though but the hair is invisible since I was unable to click on the "Make Hair" button - see attached screen shot (last)
    Once again, thanks in advance
    1296 x 873 - 487K
    1681 x 1039 - 1M
    1595 x 985 - 1M
    562 x 669 - 280K
    July 2022 edited July 2022
    You can use the easy import if you want. To make hair you have to select the scalp then the hair see the docs. You may also like to have a look at bitbucket since Thomas is working on this.
    193 x 91 - 5K
    Post edited by Padone on July 2022
    Thank you for getting back to me @Padone
    If I select the dForce Soft Curls and Soft Curls Base.001, then I do not see the option of "Bangs" - followed by an error message saying that I have to select hair and a human - see attached screenshots
    If I select the two in the opposite order, then the "Make Hair" tool is greyed out - see attached screenshot
    Also, if I try to select dForce Soft Curls and Soft Curls Base, then again the "Make Hair" tool is greyed out - see last screenshot
    Thanks again for your help
    2844 x 1672 - 1M
    314 x 206 - 16K
    2846 x 1740 - 2M
    2846 x 1706 - 2M
    Post edited by tam_c3df5332fc on July 2022
    You need to select both. Select "soft curls base" in the outliner, then hold ctrl and select "dforce soft curls". With blender you can select multiple items and the last one is called "active".
    from the docs:
    With the human selected and her hair active, press Make Hair.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
