DIM Won't Download New Purchases
Jason GalterioJason Galterio Posts: 2,562
edited October 2021 in The Commons
No matter what I do, DIM won't download the following products:
"Air-Worlds DS","17660"
"dForce Land Guard Outfit for Genesis 8 and 81 Males","81753"
"Ebil Baby for Caryn 8","64423"
"Eerie Poses for Lavinia","35099"
"Iray Sky Pro","81703"
"It Came from Outer Space Poses","58539"
"Marionette Poses for Genesis 8 Female","67087"
"Mortuorum Sacris Nosferatu","67259"
"Oceans Apocalypse Infiltrator for Genesis 8.1 Female","83046"
"Oceans Apocalypse Warrior Outfit for Genesis 8.1 Male","83078"
"Succubus Wings for Genesis 8 Females","81393"
"Succubus Wings for Genesis 8 Males","81395"
"Succubus Wings Texture Expansion","81397"
"Tank the Cartoon Tortoise","81387"
"VYK Eris for Victoria 81","82590"
"Zombie Poses for Moonshine Diner","37729"
"Just Beachy Seagrass Underwater Meadows","82463"
They come up as failed immediately after attempting to start the download.
Error log shows:
2021-10-09 01:41:26.105 WARNING: Download Error: IM00067087-01_MarionettePosesforGenesis8Female.zip : Error - 401 :
2021-10-09 01:41:26.105 WARNING: Network Error:  : Operation canceled
2021-10-09 01:41:26.105 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:42:21.146 WARNING: Download Error: IM00017660-01_AirWorldsDS.zip : Error - 401 :
2021-10-09 01:42:21.146 WARNING: Network Error:  : Operation canceled
2021-10-09 01:42:21.147 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:43:04.398 WARNING: Download Error: IM00067259-01_MortuorumSacrisNosferatu.zip : Error - 401 :
2021-10-09 01:43:04.398 WARNING: Network Error:  : Operation canceled
2021-10-09 01:43:04.398 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:43:58.257 WARNING: Download Error: IM00081387-01_TanktheCartoonTortoise.zip : Error - 401 :
2021-10-09 01:43:58.257 WARNING: Network Error:  : Operation canceled
2021-10-09 01:43:58.257 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:46:04.417 WARNING: Download Error: IM00017660-01_AirWorldsDS.zip : Error - 401 :
2021-10-09 01:46:04.417 WARNING: Network Error:  : Operation canceled
2021-10-09 01:46:04.418 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:46:04.694 WARNING: Download Error: IM00064423-01_EbilBabyforCaryn8.zip : Error - 401 :
2021-10-09 01:46:04.694 WARNING: Network Error:  : Operation canceled
2021-10-09 01:46:04.694 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:46:04.794 WARNING: Download Error: IM00035099-01_EeriePosesforLavinia.zip : Error - 401 :
2021-10-09 01:46:04.794 WARNING: Network Error:  : Operation canceled
2021-10-09 01:46:04.794 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:46:05.137 WARNING: Download Error: IM00081703-01_IraySkyPro.zip : Error - 401 :
2021-10-09 01:46:05.137 WARNING: Network Error:  : Operation canceled
2021-10-09 01:46:05.137 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:46:05.369 WARNING: Download Error: IM00058539-01_ItCamefromOuterSpacePoses.zip : Error - 401 :
2021-10-09 01:46:05.369 WARNING: Network Error:  : Operation canceled
2021-10-09 01:46:05.369 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:46:05.996 WARNING: Download Error: IM00067259-01_MortuorumSacrisNosferatu.zip : Error - 401 :
2021-10-09 01:46:05.996 WARNING: Network Error:  : Operation canceled
2021-10-09 01:46:05.996 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:46:06.923 WARNING: Download Error: IM00081393-01_SuccubusWingsforGenesis8Females.zip : Error - 401 :
2021-10-09 01:46:06.923 WARNING: Network Error:  : Operation canceled
2021-10-09 01:46:06.923 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:46:07.705 WARNING: Download Error: IM00081395-01_SuccubusWingsforGenesis8Males.zip : Error - 401 :
2021-10-09 01:46:07.705 WARNING: Network Error:  : Operation canceled
2021-10-09 01:46:07.705 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:46:08.291 WARNING: Download Error: IM00081397-01_SuccubusWingsTextureExpansion.zip : Error - 401 :
2021-10-09 01:46:08.291 WARNING: Network Error:  : Operation canceled
2021-10-09 01:46:08.291 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:46:08.944 WARNING: Download Error: IM00081387-01_TanktheCartoonTortoise.zip : Error - 401 :
2021-10-09 01:46:08.944 WARNING: Network Error:  : Operation canceled
2021-10-09 01:46:08.944 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:46:09.780 WARNING: Download Error: IM00082590-01_VYKErisforVictoria81.zip : Error - 401 :
2021-10-09 01:46:09.780 WARNING: Network Error:  : Operation canceled
2021-10-09 01:46:09.780 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2021-10-09 01:46:10.394 WARNING: Download Error: IM00037729-01_ZombiePosesforMoonshineDiner.zip : Error - 401 :
2021-10-09 01:46:10.394 WARNING: Network Error:  : Operation canceled
2021-10-09 01:46:10.394 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
I checked to see that I had harddrive space, no issues. I deleted a already downloaded product as was able to redownload that with no issue.
Items were purchased about four hours ago.
When I attempt to manually download the products I get:
code "expired_auth_token"
message ""
status 401
Post edited by Jason Galterio on
«13
  • jerhamjerham Posts: 155
    Same issue here, 401 errors when trying to download. Both from DIM and when trying to download from the site product library.
      "code": "expired_auth_token",
      "message": "",
      "status": 401
    I think Daz is having issues....
  • Jason GalterioJason Galterio Posts: 2,562
    edited October 2021
    Okay, so it's not just me...
    One item in Order History:
    Same item after clicking on Download (Product Library now):
    Error page after clicking download on previous page:
    Item in DIM after attempting to Download:
    Item shown in Error log:
    1347 x 46 - 17K
    947 x 843 - 83K
    1015 x 163 - 25K
    820 x 25 - 10K
    862 x 50 - 26K
  • AgitatedRiotAgitatedRiot Posts: 4,754
    Can I join, the me 2 crowd?
  • youri_zyouri_z Posts: 163
    Same
  • Another here!  Not all new orders, either.
  • Yeah, it won't download stuff I bought quite literally a year ago, either.
    Looks like it's just generally flaking out again. Unfortunate, as I need the shader maps for what I'm currently working on.
  • cherpenbeckcherpenbeck Posts: 1,418
    Tried several days in a row to download these items>:
    2021-05 Hair für Genesis 8 and 8.1 Female
    Alidreaux for Genesis 8 Female
    Worn Eclectic Interior
    Pandora Hair for Genesie 2&8 (Females)
    Lee 8
    Thorn for Landon 8
    dForce CB Haze Delta Clothing Set für Grenesis 8M
    iREAL animated Flocks of Birds 2 of 2
    Something is very badly broken inside DAZ Website odr download server, it seems. That does not convey competence. If I can't download the usual way (DIM), I'll wait and restrict my buyings for the time being ...
  • N00b4EverN00b4Ever Posts: 300
    Thanks for sharing your issues... I'm on the same boat.
  • 3DMinh3DMinh Posts: 294
    Same here, what happen?
  • IppotamusIppotamus Posts: 1,580
    Same, can't download a purchase.  Download failed.
  • Same issue here.
  • same here - older orders will download but not the one from today. I should've checked the forum before filing a ticket - still, at least it's been filed so someone should be able to kick the server ... but then it's the weekend already.
    Downloading using daz connect is fine, if you really need the file just download it within daz studio
  • James_HJames_H Posts: 1,107
    Same here, in UK. Some downloads worked, but many failed. I can make a list, but this seems a widespread issue.
  • Same here in Belgium
  • beachlegsbeachlegs Posts: 528
    edited October 2021
    Having same problem cannot download new item.
    Post edited by beachlegs on
  • Same problem here.
    DIM downloaded a product update OK but a newly-purchased item fails every time.
  • This has been reported, it sems to be affecting pretty much everyone.
  • MasterstrokeMasterstroke Posts: 2,403
    FG dForce Exciting Dress for Genesis 8 Female(s) (sku 56573) also fails to download.
  • Just tried again. Still happening.
  • I've found a temporary solution..... STOP PURCHASING THINGS FROM DAZ UNTIL THEY FIX THIS!
    Way too annoying to put up with. At the very least DS could post a "we're working on it" disclaimer. Or something to that effect.
  • Ghosty12Ghosty12 Posts: 2,081
    Having the same issue things are not downloading, looks like the servers have gone kahblooie again.. :(
  • frank0314frank0314 Posts: 14,852
    Please rememebr that it is the weekend and it may take a bit longer than normal to fix
  • There is no need to report further products, it's clearly a widespread issue and bumping the thread is just going to get people's hopes up that there might be some news.
  • Same problem here too!
  • This has now been passed up the chain to the web team, we are told.
  • GranvilleGranville Posts: 701
    This is a super bummer. I finally have time to work a new project and DAZ is like "Nope, not for you"
    We will let you guys know something as soon as we are notified
    BTW you can't even download manually.
    It's been reported by others that you can't download anything by all means of downloading
