Adding to Cart…
Baaaah!!! No way. It is time to get with DEC RT-11 or if your a hipster who can't handle the power then CP/M-80 for you. This will be really light on resources!!!
Is it still possible to set the Taskbar to AutoHide, so it gets out of the way when not being used?
Yes.
Phew. Thank you.
I was happy with Motorola's "VERSAdos". (early '80s) https://en.wikipedia.org/wiki/VERSAdos#:~:text=VERSAdos is an operating system,to four 14-inch platters.
Before that it was CPM (late '70s)
Before that it was the real-time, multi-processing OS on a Raytheon RDS-500 "mini-computer". (mid-'70s) I have no idea what it's name was, or if it even had a name. (old brain, lost memories)
Before that it was the real-time, single processing OS on a Raytheon 706 "mini-computer".
Before that it was the single-processing OS provided for an IBM-1130. (late '60s)
Before that it was the 3-bit, no OS, plastic "Digi-Comp-1" (early '60s) The "Digi-Comp" followed me through my career and sat on the big computers or their console for years with a sign that said "Emergency Use Only".
I was satisfied with them all, except for the Digi-Comp. Once you'd counted to 7 and experimented with AND & OR it made a good paperweight.) Not a lot of growth potential and zero peripherals.
I spent over 30 years supporting Microsoft systems, all the way back to MSDOS.
From Windows NT onwards we used to say 'Wait till Service Pack 1 comes out before you upgrade'.
Now we don't have service packs so I would say wait at least 6 months to a year from it's proper release before upgrading.
Unfortunately thanks to 'Marketing' and accountants all software released now should be consider 'beta'
Now I've retired I haven't even looked at Windows 11 and I'm not in any hurry to upgrade until Windows 10 becomes EOL.
Best Wishes
Steve.
Whilst it is true that what most of what can be done in hardware can also be done in software, that is missing the point, which is security. Anything in software can also be overwritten by a virus, or hack attack, but that is a lot more difficult, if not impossible, with hardware.
No way! AmigaDOS rules!
I don't (and won't) do widgets or active tiles or similar. I have no desire to waste resources on 'eye candy'. And my digital desktop matches my real-world desktop - unsightly stacks that I can navigate quickly and easily - the 'snap and tile' function will never get used.
I figure I've got until late 2026 to see what will be replacing this; I'm currently running two windows 7 pro systems, an OpenSuSE 15.x system, and a windows 8.1 laptop I'm in the process of replacing with a new windows 10 laptop - which will, with any luck, be upgraded from home to pro tomorrow. The W7 render system will probably get upgraded to W10 pro when a new version of Daz Studio includes a new Iray that requires a new driver that is not available for W7. The other W7 system - probably never; I use it to run a scanner, OCR scaned documents, play music and videos, reading, and writing.
I agree, don't be beta testers for MS. I would wait till the bugs are ironed out.
Yep, as usual I will also wait until it seems to have the bugs fixed. Also, I looked for that PC Helath Check app and it looks like I have to join something called the Microsoft Insider Program. I'm not much of a joiner so I declined.
The one I downloaded when it was first announced didn't require joining anything. It also wasn't any help, because it would only run on Windows 10.
Everything worked out. Win 11 Pro installed easily enough, the interface is weird. Easily find things with the search icon on the taskbar. Ran Passmark Performance Test by Passmark. 3dMark Advance Edition. Scores are on the mark with the past scores on Windows 10 pro 64. No big performance hit that I can see.
I downloaded DIM of course you had to tell windows to keep the file then it ran fine. Installed Daz3d and all content everything is working fine. Next My games.
I was content with TWM (Tom's Window Manager) in the X11R4 System on Irix on a Silicon Graphics, SunOS 1.x on a Sparc, AT&T Unix on a 386 PC or slight variants thereof for the longest time (almost 20 years); but alas those fat government contracts those corporations received made them unresponsive to the need to innovate and create better value for customers and poof, they are now history.
I like Windows as a developer of apps sort of things but I don't want to get into the Windows system OS at all as a developer or as a system administrator.
AMD Ryzen CPUs are having performance issues.
https://www.amd.com/en/support/kb/faq/pa-400
Could be as much as 15% reduction.
https://tech.slashdot.org/story/21/10/06/2026207/windows-11-might-tank-ryzen-cpu-performance-amd-warns
If you are stuck doing renders on CPU only this will be a problem until AMD gets some patches for it.
...Apple DOS 3.1
...totally agree. I prefer a rather plain & simple "old fashioned" Windows desktop with just the a simple background and Icons I need that is free of any gaudy eye candy. My workstations are just that, not glorified desktop smartphones or tablets (which is one of the reasons I was turned off by W8 and W10).
Still on 7 Pro myself and have downloaded the latest Nvidia driver I could get (which is 6 updates ahead of the one required for the version of Iray in Daz 4.15.0.30) so hopefully when Daz 5 finally rolls out, I can still render on my Titan-X, provided Nvidia doesn't move it to obsolete status for Iray (Maxwell is already in "depreciated" status).
Of course that is if Daz 5 doesn't go only with W10.and up, or is buggy as all get out (interesting that the 4.12 beta I've been using has been solid and trouble free since I installed it, even more so than the 4.12 general release that followed)..Haven't yet tried 4.15 mainly because of all the complaints about bugs and other instabilities, but wondering of some of that may have to do with W10 updates. May DL and install it to see (I have the .zips for the 4.10 and 4.11 general releases)
...part of the reason I never adopted W10 even when it was offered for "free".
My processor, an i7-7700k isn't supported, and my board doesn't include a TPM, so I'm safe from temptation to waste my time with this.
Z80 64KB RAM CP-M, I even had a 15MB hard disk or 'Winchester drive'. It was 5.25" full height and if it wasn't fastened into the cage it used to rock when the heads seeked.
<MontyPython>
You tell the young people today and they don't believe you.
</Monty Python>
Steve.
Well, at least one of my computers has a TPM header but no TPM device. And the last time I checked about availability of TPM devices they'd all been snarfed up by scalpers.
However, I really have no interest in moving to Win11 yet. Don't walk on thin ice. Give it time to solidify (or meltdown).
I just checked my three modern computers (papa, momma, & baby-bear) found that momma & baby each have a TPM header but with different pin arrangements.
Baby has a 14 pin header with one corner pin missing. Momma has a 14-pin header with a pin missing in the two-pins over from the corner. I don't yet know which pin-out is the correct one for version 2.0.
And apparently there are two types of TPM modules. Version 1.2 and version 2.0 of which only the 2.0 version is compatable with Win11. The old 1.2 version is available for $38, but the 2.0 modules (if you can find any in stock) are $80 or $120. $#!$#!#@$$!# scalpers.
And to my surprise I discovered that my most powerful motherboard (ASUS Z490) used in papa-bear doesn't have a TPM header at all.
Nor is there any mention of TPM in the motherboard manual at all.
Not Just Me: https://www.tomshardware.com/news/tpm-modules-unobtainable-expensive-windows-11
One of the main things for Windows 11 is to do with the upcoming Intel Alderlake CPU's.. As Win 11 is supposedly designed to make full use of Alderlakes big:LITTLE architecture.. But for me I will be waiting as well, to let the OS mature a bit..
If it has a TPM header and a suitable CPU you may well be able to enable a pseudo TPM mode in the BIOS/UEFI.
Same here, smooth upgrade, everything works fine and I notice a small performance improvement.
My home computer won't upgrade as it is a bit older. I am considering building a new rig and definitely will be a W11 one.
I have a Gigabyte Z490 if you have the right CPU you should be able to enable it in the BIOS under PTT
How to Check the TPM Status & Enable the CPU's fTPM/PTT • Helge Klein
Should be under Advance> Security in the BIOS
What did they screw up? This for starters:
"AMD processors officially compatible with Windows 11, exhibit a three-times increase in L3 cache latency with the new operating system.
Quoted from:
AMD Processors Lose 15% Gaming Performance with Windows 11, L3 Cache Latency Tripled
Not sure how much of an impact this actually has, but it might affect more than just gamers depending on the task(s) being performed.
...someone needs to crack down on this. Bad enough GPUs are being bought up by scalpers now they are taking advantage of those who need to update their current systems to comply with W11. Bloody parasites.
Does anyone have an MSI board? I have thisMSI Accessory TPM2SPI TPM 20 Module SPI Retail - Newegg.com for free
I have a AMD Ryzen 7 5700 APU (Zen 3) and I've noticed a performance improvement. Now I don't doubt that the bug reports are accurate but there is a limit impact to people who don't game. Only gamers are involved in the sort of repetitive cache use over & over such that's you'd actually notice those bugs to any degree at all when you suddenly wasn't as quick reflexed in your games as before. And the other is for CPUs with greater then 8 threads so likely some repetitive AI algorithms used by researchers have taken a hit in performance. The average home user won't hit those type use cases most of the time.
No. I bought this one:
GIGABYTE GC-TPM2.0_S Motherboard for sale online | eBay
but then I have a Gigabyte brand motherboard.
I'm actually not sure though if you have to match the TPM 2.0 module brand name with your motherboard brand name.
I will note that I paid $26.00 including shipping in November 2020 and now a year later (almost), the price is $62.99 including shipping. Different sellers though. I noticed over the course of 2020 on eBay that these TPM modules were selling out and it looked to be hoarders buying them as they were disappearing from eBay so fast.
